What's the easiest way to connect my PS3 and PC to my projector/displays? (diagram inside) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-24-2012, 02:26 PM - Thread Starter
pshosh's Avatar
http://imgur.com/w34VZ
I've got my PS3 currently hooked up to a projector, switching the 15ft long HDMI cable to the LCD in the same room when I occasionally play during the day (sunny window not pictured). I'd like to also be able to use the LCD in the neighboring room for PS3 gaming, or the projector as a display for my PC.
I don't mind switching cables, but the distance is a little unruly (roughly 20 feet). What are my options?
pshosh is offline
post #2 of 2 Old 07-01-2012, 05:59 PM
AV Doogie's Avatar
Quoted: 12 Post(s)
You should be able to go 20'-25' with HDMI and a HDMI switch/splitter as long as you find a quality HDMI cable for that distance.
My Home Theater Site:
DJ-Theater
AV Doogie is offline
Reply Home A/V Distribution
Playstation 3 160gb System , Projectors , Displays , Cables Interconnects , Lcd Hdtv
