Source to HDTV wirelessly? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-24-2012, 06:18 PM - Thread Starter
tvp2411's Avatar
I would like to hang my tv on wall with no wires visible. No source or furniture around it. I would like to know if i can hook up all my source(blu-ray,ps3,xbox) and HDTV to a network. HDTV will use the network to play Blu-ray movies from the blu-ray player. Is that possible? if not, any easier solution to hook everything to my HDTV wirelessly?
tvp2411 is offline
post #2 of 6 Old 06-24-2012, 07:11 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
You'll have to run power to a wall box behind the TV anyway - that may provide the opportunity to drop some low volt cables at the same time. Where do you want to put the equipment?
jautor is offline
post #3 of 6 Old 06-25-2012, 12:50 AM - Thread Starter
tvp2411's Avatar
the whole plan is, make a small hole behind TV. TV power will hook up to wall outlet. then TV wifi will connect to network. all the source will be by the computer via wifi/ethernet cable. I just dont know if the TV can receive Blu-ray signal thru the network. Or do i need some kind of switch box? Basicly i dont want any wires connect to TV. Just the TV power going to outlet. Everything else will go thru Network. I am not sure if the Network can take data from blu-ray player to TV wirelessly.
tvp2411 is offline
post #4 of 6 Old 06-25-2012, 12:27 PM
jautor's Avatar
Liked: 782
Please don't run the TV's power cord through the wall. It's not rated for that purpose and against electrical code probably everywhere... Use a PowerBridge or similar setup to provide a recessed power outlet behind the TV. These products typically have pass-through areas for HDMI and other cables to route them to less-conspicuous locations for egress...
It cannot.
There are wireless HDMI products, but they all will have a receiver portion connected to the TV. I don't know if there's one small enough to hide under the TV, and many of those products require line-of-sight, anyway.
You can run everything off of a single Cat5e cable, using an HDBaseT "HDMI over Cat5e" extender, with the other end at your equipment/receiver.
Hope that helps,
Jeff
jautor is offline
post #5 of 6 Old 06-25-2012, 06:48 PM - Thread Starter
tvp2411's Avatar
thanks alot, that clear alot of my questions.
tvp2411 is offline
post #6 of 6 Old 07-22-2012, 10:55 AM
EdL
EdL's Avatar
I use the Actiontec wireless had kit. Mine fits behind the wall mounted tv. It was reviewed in a recent hometeheatermag article. It sends the signal thru walls and does not require line of sight. I get handshake issues when the signal passes thru my yammy a2000.
EdL
EdL is offline
Reply Home A/V Distribution
