Anyone ever run wires through walls AFTER sprayed insulation? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-26-2012, 09:55 AM - Thread Starter
Chad711's Avatar
I bought a new home and they used sprayed insulation on the outside walls. I would like to run some wires but remember the installer telling me it will be very difficult. So anyone done this? How did you do it and was it a PITA?
I have a home network system that was installed so there is already wires running through this stuff that they put in before the sprayed. Not sure if that helps me or not?
Thanks for any feedback!
Edit: Everything I'm reading sounds like it's not ideal to try and do this. If so I need to figure out a way to run surround sound wires behind my couch in my game room. Guess I could pull carpet and punch a small hole in carpet for wires? I can't seem to find blue tooth connected speakers anywhere besides the soundbar subs. I'm looking for a 5.1 setup.
Chad711 is offline
post #2 of 9 Old 06-26-2012, 11:28 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
If the sprayed stuff SOLIDIFIES then indeed would be PITA. If like regular "cotton" then is entirely do-able, I used fiberglass rods for that.
MrBobb is offline
post #3 of 9 Old 06-26-2012, 11:41 AM - Thread Starter
Chad711's Avatar
It's the sprayed stuff. Ok, not even going to mess with it.
Chad711 is offline
post #4 of 9 Old 06-26-2012, 12:47 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I don't have the sprayed, but I've read it's pretty easy to pass a straight run through it, same stud cavity, using a steel fish tape (and I assume fiberglass rods).
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 9 Old 06-26-2012, 12:48 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
And, the foam may not even be filling the entire stud cavity. Might just be 3" thick.
Neurorad is offline
post #6 of 9 Old 06-27-2012, 02:10 PM - Thread Starter
Chad711's Avatar
What do you mean "same stud cavity"?
Oh and it is packed all the way. I saw it during a walk through during construction and they pack it in there all the way!
Chad711 is offline
post #7 of 9 Old 06-27-2012, 03:01 PM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
Meaning the same vertical space between studs ( a 'stud bay'). You can probably poke/fish vertically with some practice by staying next to the underside of the drywall. But leaving the stud bay is going to be a challenge. That would probably be the cue for the expert to come in...
If you have a path around the room, you could hide wires behind crown molding, poking into the drywall at the top and down (within the stud bay) at the entrance/exit points (the amp location and the speaker locations).
Jeff
jautor is online now
post #8 of 9 Old 06-28-2012, 11:27 AM
gatorchris's Avatar
There are two kinds of spray foam, open-cell and closed-cell. Open-cell is soft and spongy and you can easily push a rod or fish tape through it. Closed-cell dries hard as nails. Im sure with enough work you could push something through closed-cell but it would be a serious pita. You should know what you have if you touched the stuff during construction.
gatorchris is offline
post #9 of 9 Old 06-28-2012, 05:44 PM
BradKas's Avatar
BradKas is offline
Reply Home A/V Distribution
Cables Interconnects
