Runing RG6 next to Romex (electrical power)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-01-2012, 03:26 PM - Thread Starter
wacki's Avatar
I'm fishing wire through the walls. The floor joists under the living room have a hole in it with just enough room for me to feed RG6 for the sub-woofer sitting behind the couch.
How bad is it that Romex is sharing the same hole as RG6? How far apart should they be?
Trying to make things all nice an tidy so the girlfriend will be happy but the way the house is laid out this is NOT easy. And I really don't want to drill any more holes in the floor joists.
wacki is offline
post #2 of 2 Old 07-01-2012, 05:53 PM
AV Doogie's Avatar
Quoted: 12 Post(s)
Not an ideal situation, but you can run your RG6 next to the Romex without trouble.
My Home Theater Site:
DJ-Theater
AV Doogie is offline
Reply Home A/V Distribution
