Best Coaxial Connectors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-01-2012, 06:57 PM - Thread Starter
wacki's Avatar
I'm fishing RG6 through the walls for the home theater. What are the higher end coaxial connectors? None of the ones I see at Fry's are gold plated.
wacki is offline
post #2 of 6 Old 07-01-2012, 07:03 PM
AV Doogie's Avatar
I would not worry about gold plated connectors. The compression type F connectors are excellent (these are the type used by the cable companies)
http://www.mcmelectronics.com/product/27-5845&cid=prodCrossSell
or at frys: http://www.frys.com/product/4894060?site=sr:SEARCH:MAIN_RSLT_PG
and typical tool
http://www.mcmelectronics.com/product/22-14545&green=A5D05D06-6FBF-58A0-0AA8-FFB38031D583&utm_campaign=MyBuys&utm_medium=Recommendation&utm_source=prod&utm_term=22-14545
or the tool and connectors at Frys:
http://www.frys.com/product/3916028?site=sr:SEARCH:MAIN_RSLT_PG
My Home Theater Site:
DJ-Theater
AV Doogie is offline
post #3 of 6 Old 07-03-2012, 10:27 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
+1 for the compression fittings.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 6 Old 07-04-2012, 01:18 AM
cwpl's Avatar
Would the less expensive compression tool's work ok for homeowners (occasional use)?
cwpl is offline
post #5 of 6 Old 07-04-2012, 02:21 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Yes
CIAO!
Ed N.
egnlsn is offline
post #6 of 6 Old 07-05-2012, 02:29 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
This is what I use and they are very good. Fairly inexpensive as well.
It's a combo kit so you get the compression tool and a coax stripper.
http://www.specialized.net/Specialized/HCPT6590-Hybrid-Pkt-Compression-Tool--CPT6590Single-Stripper-5845.aspx?src=banner
ifor is offline
Reply Home A/V Distribution
Cables Interconnects
