Expandable Matrix Switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-05-2012, 02:52 PM - Thread Starter
samp81's Avatar
I am purchasing a component matrix switch over the next couple of days. Big thing for me is expandability. I can start with a 4x4 now, but will get up to as many 7 or 8 inputs and 12 outputs. I see getting up to 12 outputs. Right now its down to the HLX modular system by Audio Authority and the Idaho 8 x 9 from HD TV Supply.
I have seen a few reviews for the HLX, none for Idaho. Would love to hear from anyone that has tried the Idaho; general thoughts and opinions are good too.
samp81 is offline
post #2 of 3 Old 07-05-2012, 09:06 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
The AudioAuthority units are awesome. Never heard of Idaho (well, not in the A/V context biggrin.gif)
Do you need more than 4 sources? I've recently expanded my Aton HDR44 to 12 zones with a 3rd unit. If I really needed more than 4 sources, I could probably section them off onto one of the 4x4 units - with some thoughtful planning, you may not need an 8x8. For example, if you're going to hook 4 set-top boxes to an 8x8, hooking two each onto 4x4 units, and grouping the outputs logically based on expected usage, you may get very close to the same functionality...
Jeff
jautor is online now
post #3 of 3 Old 07-05-2012, 10:21 PM - Thread Starter
samp81's Avatar
I am going to start with 4x4 and go from there. I saw the Aton. Problem is I do not have 2 Cat5 runs to all the rooms. AudioAuthority has an option for tose rooms.
samp81 is offline
Reply Home A/V Distribution
Audio Authority
