What Is Best Way to Find Russound Installer In Orlando, FL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-17-2012, 03:20 PM - Thread Starter
AJ2012's Avatar
I'm having issues with my Russound system and looking for a qualified tech for repairs. Is there a directory somewhere?
AJ2012 is offline
post #2 of 6 Old 07-18-2012, 05:40 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I would start with Russound tech support. They might know a local company.
Your problem may be with a bad device or bad wiring. Most qualified custom installation companies could figure out if it's hardware or an installation issue. I would try calling a few.
What Russound product line?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #3 of 6 Old 07-18-2012, 06:46 AM - Thread Starter
AJ2012's Avatar
It's a CAV 6 system
AJ2012 is offline
post #4 of 6 Old 07-18-2012, 07:03 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
The cav, I believe, could be bought off the shelf. I think most local custom installers could service that.
Ask around at work for company recs, if Russound TS doesn't have some recs.
post #5 of 6 Old 07-18-2012, 07:09 AM - Thread Starter
AJ2012's Avatar
Thanks.. I appreciate it. Do you know is there a way to contact someone directly on this forum that has responded to questions? I noticed someone by the forum name of JBSmoothie that is from Orlando and that had posts on other questions and seemed to have knowledge of the Russound systems. Thanks again
AJ2012 is offline
post #6 of 6 Old 07-18-2012, 08:24 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
Click on his name under the avatar and select "send PM" (private message) Hmmm, maybe the forum guys should spell that out instead of using an acronym... smile.gif
jautor is online now
Reply Home A/V Distribution
