IR over CAT5 - How to terminate at wall? - AVS Forum | Home Theater Discussions And Reviews
Old 07-18-2012, 08:28 PM - Thread Starter
mshe's Avatar
Hi all,
I'm planning on running CAT5 from my IR receiver to a location behind my AV receiver; how do you terminate your IR cables coming out of the wall?
While I know I can terminate directly into a IR distribution box, I was hoping for some sort of jack or wall jack.
I saw someone posted a Buffalo IR Junction box but this looks to be surface mount - any ideas about flush mounting?
Do you guys just terminate into a RJ45 keystone and then patch from there?
mshe is offline
Old 07-18-2012, 10:50 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
I'd just do an RJ45 and make a patch cable for your emitter, but I have seen 3.5mm keystone jacks, which would allow you to hook up an emitter cable. Just note that if this is coming from an IR receiver, you must have a stereo jack, as the receiver needs 3 signals (power, IR, ground). Cables-to-Go sells these...
Jeff
jautor is offline
Old 07-19-2012, 01:23 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
http://www.newtechindustries.com/products/Keystone-Type-Insert-IR-Socket-Stereo.html
This one is stereo (i.e. 3 conductors for an IR receiver); they have a mono version for an IR emitter as well.
cshepard is offline
Old 07-19-2012, 01:24 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Jeff
They did, but I don't see them anymore.
cshepard is offline
Old 07-19-2012, 06:21 PM
jautor's Avatar
Liked: 777
The one you linked to is cheaper and looks better anyway!
jautor is offline
Cat5 Rack 1u
