NuVo Essentia - want to connect my PC or Mac - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-20-2012, 07:30 AM - Thread Starter
akssecure's Avatar
Hey guys - sorry for the Noob-age.
Bottom line is that I was wondering if any of you have written a plug-in which will permit an instance of iTunes on a Mac or PC to play through the NuVo, and transfer the metadata etc over NuVoNet, so that the track info etc is displayed on the keypads. Bonus points if you can control the iTunes instance via the keypads.
Ideally, we could connect the ethernet port or serial (more likely) as a device onto the all port and go from there...
Any help?
akssecure is offline
post #2 of 4 Old 07-20-2012, 08:05 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
The original NuVo Music Port (NV-MP) was exactly this... It's a combination of a NuVoNet adapter (serial to NuVoNet) and the Autonomic Controls Mirage software. No longer sold, but they do pop up on eBay.
Easier to find (and a current, supported product) would be to get just the NuVoNet adapter (NV-NNA) by itself (same adapter, just no software bundle) and buy a copy of CasaTunes - which has very similar functionality. My only gripe with CasaTunes is the lack of native Pandora support, but they do have Airplay support, so you can get there - but without metadata / control. You can also buy a copy of the Mirage software from Autonomic, which does support Pandora, but hasn't been updated in quite a while (as they've been focused on their music server products).
By far the easiest, but more expensive, path is to just get the NuVo MPS4 server (or the Elite, which supports network-shared libraries), which has everything done for you.
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 4 Old 07-27-2012, 08:23 PM - Thread Starter
akssecure's Avatar
Thanks so much for the tips! It's odd about the lack of Pandora support... still - I'm excited!
Appreciate the assist.
post #4 of 4 Old 07-27-2012, 08:24 PM - Thread Starter
akssecure's Avatar
Reply Home A/V Distribution
