Need Help With Component Output from PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-20-2012, 12:06 PM - Thread Starter
BlackWS6LS1's Avatar
Folks,
First off in short I need to be able to add a few PC DVI outputs to a existing Video Matrix switcher.
Below is the existing equipment that is already working fine:
Xantech High Defintion Video Matrix Switcher
http://www.xantech.com/Video/HighDefinition/HDVideoAudioDistrib/HD88CC5/
Xantech HDRXSG01 HD receiver
http://www.xantech.com/Video/HighDefinition/SingleGangHDTrans/HDRXSG01/
Dish Network and BluRay Players
Solo VIP 211k
Sony BlueRay
Sharp Aquas TV
http://www.sharpusa.com/ForHome/HomeEntertainment/LCDTV/Models/LC70LE640U.aspx
I am trying to add a 1080 output from a PC to the XANTECH, however I'm running into an issue with signal.
Here are the pieces that I'm using to try and make it all work.
Video Card ATI FirePro 2450
http://www.amd.com/us/products/workstation/graphics/ati-firemv-2d/ati-firepro-2450-mv/Pages/ati-firepro-2450-mv.aspx
DVI to Component Converter - Attempt #1
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023504&p_id=3869&seq=1&format=2
Stilling looking if the Video card can display the proper format, thinks its analog VGA output.
DVI-I Male to 3 RCA Component Adapter w/ DIP Switch for ATI Video Cards
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041901&p_id=2398&seq=1&format=2
Same issue.
I'm guessing that is will require another Video Card and or a phyiscal electric converter of some type. Please give me another help that you can.
Tom
BlackWS6LS1 is offline
post #2 of 6 Old 07-20-2012, 12:24 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
That card has VGA outputs as well - use VGA-to-component, which will be much easier than trying to get back from a digital signal... I assume the FirePro's breakout cable has all those connectors?
Jeff
jautor is offline
post #3 of 6 Old 07-20-2012, 01:24 PM - Thread Starter
Jeff
Yes it does but what kind of calbe will I need to go from a VGA analog to Component Video YPbPr (YCbCr)?
Tom
post #4 of 6 Old 07-20-2012, 01:32 PM
jautor's Avatar
Liked: 777
First, check to see if the video card will support a YPbPr output on the VGA port (many do) - it's sometimes called "HDTV output". If not, there are converters to get from VGA to component, but the results are likely better / cheaper than trying to do an external digital-to-analog solution.
EDIT: Removed link to product that was really only 480p capable...
Jeff
jautor is offline
post #5 of 6 Old 07-23-2012, 06:16 AM - Thread Starter
Jeff
Just check all the specs, the output is not on any of the cut sheets.
Wonder if I contact them anyone would really know.
Tom
post #6 of 6 Old 07-31-2012, 02:12 PM - Thread Starter
Anyone else? I asked a few other boards and they suggested this card..http://www.amd.com/us/products/workstation/graphics/ati-firemv-2d/2460-mv/Pages/2460-firemv.aspx But it doesn't work either.
Is converting to VGA then component the real way?
Reply Home A/V Distribution
