Connect multiple LCD TV from Laptop - AVS Forum | Home Theater Discussions And Reviews
Old 08-04-2012, 01:25 PM - Thread Starter
xenonneon's Avatar
Hi Experts. A newbie question.
Specification:
1) One laptop with VGA, HDMI and S-video output
2) Three LCD TV where the maximum distance from laptop to any laptop is 100 ft.
3) I need to show the screen of laptop to all three LCD at the same time. The composite input of TV is already used.
Going through the forum, I think the best solution is VGA/HDMI over cat5.
If the above is true then can someone suggest some good quality baluns, VGA/HDMI cable etc.
if anyone has a better solution please post it.
Thnx.
xenonneon is offline
Old 08-05-2012, 05:39 AM
HCCDesignGuy's Avatar
Well, as much as I'm a believer in wires; this may be a better solution for your needs:
http://go.iogear.com/lp/GHDSSW4/?src=HPBanner
These are available in kits which are -pre-paired (so you don't have to screw with doing your own pairing of multiple receivers to a single transmitter.
I have used these in multiple installations at this point where running wires was going to be quite invasive and create lots of mess & labor costs. That said, after seeing how well they perform; including in installs where I'm going between floors, walls, etc., I feel they are a good solution EVEN IF YOU DON'T NEED TO SIMPLIFY THE INSTALLATION from wiring challenges.
From a cost standpoint, they are not much more expensive than even cheaper HDMI baluns.
There multi-input/output capability makes them ideal for use with pretty much any display and they can upconvert from Component to HDMI.
HCCDesignGuy is offline
