Split and convert Component video 480i - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-06-2012, 08:06 PM - Thread Starter
smilejack1's Avatar
I currently output 480i component video from my HTPC to my AV receiver. I would like to also send a video signal to my kitchen TV. Since my receiver does not convert the signal which is input into it, and since it has only one set of Component outputs, I will (it seems to me) need to split my HTPC's Component signal (which I understand requires amplification for good picture quality) into two branches. One can then go to the AV receiver, and the other will need to be converted to either composite video or coax.
What hardware will provide the easiest (ie, cheapest) way to do this? My budget is very tight right now, and all help is appreciated.
smilejack1 is offline
post #2 of 2 Old 08-06-2012, 11:42 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
You might be able to get away with just some Y-cable splitters, and then Monoprice has a Component to Composite converter...
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=7114&seq=1&format=2
No experience with that, but Monoprice has a good return policy.
Jeff
jautor is offline
Reply Home A/V Distribution
