Nuvo Grand Concerto - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-08-2012, 04:45 PM - Thread Starter
AV Dumb's Avatar
I am trying to replace a keypad for a Nuvo Grand Concerto I installed it and it is telling me "NuVo net not connected".
Any ideas?
AV Dumb is offline
post #2 of 4 Old 08-08-2012, 06:34 PM
jautor's Avatar
Quoted: 1307 Post(s)
Liked: 836
Did you connect it to the correct RJ45? There's two on the back.
Next, unplug the GC from the EZport, and connect the keypad directly with a patch cord.
What was wrong with the previous keypad? Are you sure it's not a wiring or termination issue?
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #3 of 4 Old 08-09-2012, 08:37 AM
Neurorad's Avatar
Quoted: 230 Post(s)
Liked: 145
Reboot the GC.
Check the terminations with a $20 HD/Lowes cable tester.
Use a different port on the EZport. Similar to what jautor said, bring the keypad to the EZport and try a different port.
Retrieve the configuration program from the GC, make a minor change, and send it back.
Any remodeling done recently? Nailed/screwed cable as the cause? New kink in the category cable?
Sometimes waiting a day will fix the issue, magically.
RS485 networks can be finicky. How many total zones, and what size house? I think there is a 3000 foot limit total to the RS485 network, with each category cable length doubled (to keypad and back).
Unplug every keypad, and add them back one at a time, confirming each keypad works as it is added.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 4 Old 08-09-2012, 08:39 AM
Neurorad's Avatar
Quoted: 230 Post(s)
Liked: 145
If you can't get it to work after a couple weeks of trying, call the distributor for more tips. If the distributor runs out of ideas, then call Nuvo tech support.
If the distributor is no longer a Nuvo dealer, then call Nuvo TS.
Neurorad is offline
Reply Home A/V Distribution
