RF modulator, demodulator? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-16-2012, 10:46 AM - Thread Starter
Mendozer's Avatar
I got a new TV which only has 2 HDMI, RF, and component/audio hookups. I don't have cable anymore, using netflix and hulu. I want my "free cable" sound to come out of my speaker system. I got an RF modulator, but that didn't seem to help. How do I take the RF out of the wall and convert it to be used for audio to the system?
My receiver has no RF port so I can't do it that way. I was thinking of something that converts RF to composite AV. Then I'd use an output from the receiver (component) to go into the TV. My other TV connection used is my PS3 using HDMI.
will this work? what kind of adapter, converter do i need?
thanks
Mendozer is offline
post #2 of 17 Old 08-16-2012, 11:06 AM
SAM64's Avatar
Liked: 78
Use a TV tuner.
SAM64 is offline
post #3 of 17 Old 08-16-2012, 11:26 AM - Thread Starter
Mendozer's Avatar
is that the simplest option? They're pricey so i was trying to avoid that.
so RF -> Tuner; composite -> Receiver input video/audio. Receiver output - > TV component video only
correct?
Mendozer is offline
post #4 of 17 Old 08-16-2012, 11:35 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
Does the TV not have an audio (analog or digital) audio output? Assuming you're using the TV's tuner, that's the best way to get the OTA audio to your AVR...
jautor is online now
post #5 of 17 Old 08-16-2012, 11:39 AM - Thread Starter
Mendozer's Avatar
it doesn't have an audio output, unless i've totally missed it
it's this one http://www.samsung.com/us/video/tvs/LN32D405E3DXZA
2 HDMI (in)
1 component (in)
1 composite (in) (audio only)
1 USB
Mendozer is offline
post #6 of 17 Old 08-16-2012, 11:50 AM
jautor's Avatar
Liked: 780
Nope, you didn't miss it... That's a surprise. I guess the makers have simplified / cost-reduced the features out of the "moderately-sized" displays, probably assuming most folks are using set-top boxes which makes the feature(s) redundant or unused anyway... That's too bad.
No really good answer for you other than a set-top box. Or another TV. biggrin.gif
Jeff
post #7 of 17 Old 08-16-2012, 12:13 PM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
You didn't list any other equipment you might have but there are a number of boxes that will get you what you want.
Apple TV does Hulu plus and Netflix but not Hulu but it has HDMI out and also
A number of the new DVD and BluRay players can get Hulu plus and Netflix.
I think X box does it also. Surprising your TV doesn't have analog or digital audio out.
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
post #8 of 17 Old 08-16-2012, 12:18 PM - Thread Starter
Mendozer's Avatar
update:
i have a ps3 accessing netflix going HDMI to TV
I have a Kenwood 5.1 with receiver (VR5000 if i remember correctly). has a couple components, composites, optical audio (used by ps3) etc. It doesn't have RF though.
so basically i need a tuner box with composite at the very least. like those digital converter boxes that take RF into composite. that can go into the receiver then component can go into the tv from the receiver.
Mendozer is offline
post #9 of 17 Old 08-16-2012, 12:48 PM
SAM64's Avatar
Liked: 78
It's the only option. You need a tuner to demodulate the signal into baseband.
SAM64 is offline
post #10 of 17 Old 08-16-2012, 06:22 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
What who where? Uh? First you say you don't have cable, then your source is from hulu/netflix (no RF here) then you need an RF converter. WHAT?
MrBobb is offline
post #11 of 17 Old 08-17-2012, 08:42 AM - Thread Starter
Mendozer's Avatar
thanks
there's still an RF outlet on the wall with free over the air cable, like 30 channels. Basic ones like fox, abc, cbs, etc
Mendozer is offline
post #12 of 17 Old 08-17-2012, 10:13 AM
jautor's Avatar
Liked: 780
"Off-the-air" (free broadcast) isn't "cable" (pay TV service), hence the confusion... But the answer remains the same.
post #13 of 17 Old 08-17-2012, 10:20 AM - Thread Starter
Mendozer's Avatar
so when i do get a tuner, i'm probably going to have to use the tuner's remote, not the TV's right? i just hate the clutter. hope it's worth the 5.1.
Mendozer is offline
post #14 of 17 Old 08-17-2012, 10:30 AM - Thread Starter
Mendozer's Avatar
upon closer inspection, i found a coax video input (one that requires one of these).
however, that "optical in" audio is taken by the ps3. Can i still use the coax adapter to feed video into that, then use composites from "video 1" to go out to the TV ? and i was mistaken, there are no components, just composite.
Mendozer is offline
post #15 of 17 Old 08-17-2012, 12:01 PM
jautor's Avatar
Liked: 780
Huh? "Coax video input" on where? Anything coming into your house on coax will not work on any input with an RCA jack. You have to take your OTA and feed it to a tuner. Where are you located (US or Europe)?
Jeff
post #16 of 17 Old 08-17-2012, 06:39 PM - Thread Starter
Mendozer's Avatar
i was supposed to attach this picture on the last post. my bad
i'm in US
Mendozer is offline
post #17 of 17 Old 08-18-2012, 12:42 AM
jautor's Avatar
Liked: 780
No, that is a digital audio (SPDIF) input, and will do you no good. The OTA signal coming from your antenna (or shared building antenna / cable headend system, whichever it is) is a modulated ATSC/QAM signal which has to be demodulated and decoded. Only thing that does that is an HDTV tuner.
Reply Home A/V Distribution
