Odd Speaker wiring in house help me understand. - AVS Forum | Home Theater Discussions And Reviews
Old 08-17-2012, 07:48 AM - Thread Starter
juicegoose's Avatar
This might not be the right place but I didn't know where else to post it. We recently moved into a new home(built in 2004). Where all of the AV equipment/speaker wiring comes out of a wall there was 2 RG6 jacks. After having the satellite guy stumped for a solid hour as to why one didn't work I figured out that one of the jacks was wired to the central distribution unit for the homes satellite and networking and the other simply ran from the jack through a stud to the right and then was bundled into the speaker wiring. The only thing I can think of is that this allows for the home owner to hook all the speaker wires up together including an rg6 wire for a sub. The speaker wires then go up into the ceiling and like I said the rg6 cable just goes about 2 feet to a jack in the wall. Am I crazy or is this for a sub connection? It its not then what might it be for?
juicegoose is offline
Old 08-17-2012, 08:38 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Sounds like a subwoofer connection, from what you describe.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 08-17-2012, 08:40 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Certainly sounds like a subwoofer connection. Running coax for a sub is common practice... The short distance could be for looks, but I'll guess that the original owner paid for a "5.1 install", and so even though the placement of the sub could have been done without a cable in the wall - that's what he paid for!
Jeff
jautor is offline
Old 08-17-2012, 08:59 AM - Thread Starter
juicegoose's Avatar
Thanks for the verification. Would you guys think it would effect sound quality any by having the multiple connections? Also I just picked up my first powered and and was going to run the coax to it. If i used the wall plate I would need the make a RG6-RCA cable right?
Old 08-17-2012, 09:23 AM
jours's Avatar
They make RG6 to RCA inserts for those wall plates. You screw the RG6 to the inside of it an connect a regular RCA to the outside.
Edit:
Like this. Lowe's had them on the shelf last time I was there.
jours is offline
Old 08-17-2012, 09:39 AM - Thread Starter
juicegoose's Avatar
Brilliant!!!!!!
Old 08-24-2012, 06:29 AM
Netko350Z's Avatar
That is my worst fear... buying a house that someone else decided to wire up for A/V
Netko350Z is offline
Speaker Systems , Cables Interconnects
