Home pre-wired but no diagram left - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-19-2012, 11:10 AM - Thread Starter
KWP
KWP's Avatar
Hi, I've searched several threads, but can't see to find the right answer to my questions.
We bought our home new 7 years ago and the screen porch and family were pre-wired, but they didn't leave a diagram like they did in our old house in Seattle. The wiring includes 2 cat5 runs and 4 speakers and 2 speaker wire runs to the screen porch.
Anyway, I bought some Def Tech AW5500's for my screen porch and hooked up the wires to the receiver. I decided to test out the connections before hanging the speakers, but got no sound.
Here's my connection points as I see them. Can anyone tell me if I need to add something? Do I need a volume control at the door leading to the screen porch? I'm surprised that the connections "end" at the point going out to the screen porch. I thought that a volume control would be optional there and the cables would run directly to the porch.
I'm not worried about putting speakers in the family room as I have a full theater in the basement.
Connection point:
Volume control location leading to the screen porch:
Speaker connections on porch:
Volume control location in the family room. It looks the same as the screen porch connection:
KP
KWP is offline
post #2 of 7 Old 08-19-2012, 11:20 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 782
The volume control is optional - you just need to connect the incoming / outgoing wires together at the volume control location. Simply splice them together and you're done!
Jeff
jautor is online now
post #3 of 7 Old 08-19-2012, 11:30 AM - Thread Starter
KWP
KWP's Avatar
Jeff
WOW. Now that I noticed two sets of single wires, I see that now. Thank you so much!
KP
KWP is offline
post #4 of 7 Old 08-19-2012, 12:49 PM - Thread Starter
KWP
KWP's Avatar
*Edit* I tried it. It doesn't work. I've verified that the speakers and the receivers do work, but I can't get any sound. This is weird. There are no other dead plates where I think I should make connections. Any other ideas?
KP
KWP is offline
post #5 of 7 Old 08-19-2012, 12:57 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Invest in a $10 ohmeter, from HD/Lowes. Test the wires for continuity.
You have 4 conductors/wires in each cable at the VC locations? 4 different colors?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 7 Old 08-19-2012, 02:10 PM - Thread Starter
KWP
KWP's Avatar
Will do. I do need one of those.
And in the wires I'm trying to connect, there is only two colors, red and black. I just don't get it.
KP
KWP is offline
post #7 of 7 Old 08-19-2012, 03:27 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
How many wires are in each of the speaker cables at the VC?
Neurorad is offline
Reply Home A/V Distribution
Definitive Technology Aw 5500 Outdoor Speaker Single White , Speaker Systems
