DIY Retrofit wiring? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-26-2012, 12:49 PM - Thread Starter
memmo's Avatar
Quoted: 76 Post(s)
Liked: 66
I get the keys to the new house this week and my first "project" is to properly wire the home for a distributed A/V system.
As such, I'll need a bunch of Cat6 and some speaker wire run to nearly every room in the house. It's a largish 2 story home that has an unfinished basement. After doing a bunch of research and reading here on AVS, I think I'll need a large conduit running from the basement equipment room to the attic where I can distribute cabling to each room and then drop down to required locations. Main floor seems a little more tricky but I'll come up from the basement.
I'm wondering what the general consensus is -- with an investment in some key tools and a couple of buddies to help out, is this a reasonable project to take on in a DIY fashion?
I did get a bunch of quotes from local Alarm companies, customer integrators and an electrician -- most in the $4k-$5k range without materials.
As I can source the materials inexpensively from a local supplier the cost savings would be significant if I could pull it off. I have family members who are handy with drywall so patch work probably won't be too difficult.
Thoughts?
The Big Bay Home Theater Build Thread
My personal theater build on Kempenfelt Bay, Barrie Ontario Canada
memmo is offline
post #2 of 3 Old 08-26-2012, 01:33 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
In your case, with unfinished basement below and attic above, I think DIY retrofit is do-able, especially if you have the luxury of time - install piecemeal over the next year, take your time planning it out.
I found a big chase around my fireplace to retrofit conduit, attic to basement.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 3 Old 08-26-2012, 01:37 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I accessed the chase from 2 adjacent closets, one on each floor, and installed access panels to avoid repairing drywall, and so that I can add more conduits in the future if needed. I installed 2" orange LV flex conduit x 4.
Neurorad is offline
Reply Home A/V Distribution
New Steren Cat 6 Coupler Adapter Kv7180 , Cables Interconnects
