Recommendation for vendors in Michigan area to complete wiring - AVS Forum
post #1 of 3 Old 08-27-2012, 09:09 PM - Thread Starter
swtech's Avatar
Hi, Hope I'm not breaking any rules here. Just looking for recommendations. Anyone work with a quality vendor in Michigan, Ann Arbor/Brighton area, that does pre and finish wiring for new construction? Been looking around a bit and found a few small businesses (one man) but none have been the right fit. Will likely need the job done in the next 3 to 4 weeks, been reading a lot here and have learned that I need professional help :-)
sw
swtech is offline
post #2 of 3 Old 08-28-2012, 02:42 AM
Neurorad's Avatar
Liked: 76
I suggest you search the CEDIA website, and check references.
And, ask around at work for recs.
But, with a 3-4 week lead time, you may not have the luxury of being too picky.
Best of luck!
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 3 Old 08-29-2012, 06:27 PM - Thread Starter
swtech's Avatar
Thank you, I found a couple of vendors on Cedia site.
swtech is offline
Reply Home A/V Distribution
Cables Interconnects
User Tag List
