HELP...Share components between a projector and a tv. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 09-02-2012, 08:02 AM - Thread Starter
hardcorecamraman's Avatar
I'm in dire need of assistance so any input would be appreciated. I am getting a bar installed and have the current setup:
Sherwood New Castle R-865 (yes I know...it's a bit out dated)
Connected to it is a HD-Cable Box, DVD Player, and DLP Projector
What I would like to do is be able to share the components with the new TV at the bar.
My question... how (if possible) can I run cables to the tv at the bar without having to point the remote at the components(across the room) and has the least amount of signal loss?
Hardware suggestions, model numbers, etc. Would be helpful. The only options I see are either to split the monitor out(component) to the projector and the new tv(which I'd still need to run some kind of ir receiver...any suggestions?) or run cables using room 2 option but I would still need an ir receiver near the new tv AND it is composite out and not component.
Again, any feedback is appreciated.
hardcorecamraman is offline
post #2 of 17 Old 09-02-2012, 10:35 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Simplest remote solution would be to convert your remote(s) to RF using the "Next Generation Remote Control Extender":
http://www.amazon.com/Next-Generation-Remote-Control-Extender/dp/B000C1Z0HA/ref=sr_1_1?ie=UTF8&qid=1346603540&sr=8-1&keywords=next+generation+remote+control+extender
If you're using component video, you could either add a distribution amp/splitter and long cables, or use a component-over-cat5 setup. CE Labs has the CAT5TX / CAT5RX pair that has a "loop output" so it's easy to add to an existing setup. There are cheaper solutions, but I've seen mixed results with some of them, so YMMV...
Jeff
jautor is offline
post #3 of 17 Old 09-04-2012, 05:27 AM - Thread Starter
have you had any personal experience with the Next Generation Remote Control Extender? I was told I should be able to get by with just a simple component splitter as well but trying to get some feedback.
post #4 of 17 Old 09-04-2012, 08:39 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I second Jeff's recommendation for the NextGen remote extender, I've been using one for several years to control components in my basement from my bedroom on the 1st floor. It works with most remotes but not with remotes that use their own rechargeable battery packs. What makes the NextGen unique is that the transmitter resides inside the remote's battery compartment so there's no need to point the remote at anything....highly recommended.
Vin
Vin is offline
post #5 of 17 Old 09-04-2012, 02:33 PM
jautor's Avatar
Liked: 777
Yes. Works great. And +1 on everything Vin said...
jautor is offline
post #6 of 17 Old 08-14-2013, 10:40 AM - Thread Starter
Hey all.
So I am running the receiver with a radio shack splitter. Cable video and audio is great. Though when I switch to dvd(sd) the audio is very low. Any thoughts? I currently have is running with both component and composite audio and neither of them work. The cable is connected digital audio.
post #7 of 17 Old 08-14-2013, 10:53 AM
jautor's Avatar
Liked: 777
The output levels of analog vs. digital products may be different - your AVR may have a setting to adjust these differences between sources.
What signals are you splitting? Analog audio volume will be affected by passive splitters, but the digital signals will not. At least, not directly in terms of volume.
Jeff
jautor is offline
post #8 of 17 Old 08-14-2013, 12:22 PM - Thread Starter
Jeff,
Audio signals into the receiver are digital and they are analog going out. I can't figure out why the cable volume is fine and yet the dvd volume isn't. I would think if it is being split coming out of the receiver and the cable to the second tv is the one carrying the signal then the audio would be messed up for both sources. Now, the only way it seems I can get audio is using a room 2 option which it is as if the audio from the dvd player is carried on a second cable. :-(
post #9 of 17 Old 08-14-2013, 02:21 PM
jautor's Avatar
Liked: 777
Where are the audio levels different? Is this from speakers attached to the AVR, or the TV speakers?
Audio levels can and will be different from source-to-source, unfortunately.
jautor is offline
post #10 of 17 Old 08-14-2013, 06:50 PM - Thread Starter
The audio level are extremely low on the tv. There is also a slight humming which is not present when watching cable. I have never experienced anything like this when splitting audio. As mentioned it almost sounds like the audio from the dvd is a separate cable but it isn't. I am completely clueless.
post #11 of 17 Old 08-14-2013, 09:02 PM
jautor's Avatar
Liked: 777
What are you splitting, and what cables EXACTLY are running to the TV and where are they coming from? Most TVs don't have digital audio inputs, so the audio is coming from somewhere else...
jautor is offline
post #12 of 17 Old 08-15-2013, 06:19 PM - Thread Starter
Audio is digital out to Sherwood New Castle r-865 and out component. The thing is the audio out from the receiver goes directly to the tv so that isn't split.
post #13 of 17 Old 08-15-2013, 06:35 PM
jautor's Avatar
Liked: 777
Component is video-only, not audio. If you're taking a 5-RCA cable from the Sherwood to the TV (with red/white RCA), that will be analog audio. If so, where are those L/R (red/white) analog audio jacks connected on the Sherwood? They will need to be on a fixed output - pre-amp outputs will be variable. A "tape loop" record out is a good choice.
jautor is offline
post #14 of 17 Old 08-16-2013, 01:06 PM - Thread Starter
Hmm will have to try. They are connected to the analog outs for room 2 on the receiver. I will try one of the other outputs but I am not sure if I can listen to audio different then the video input at the same time. I guess theoretically I should be able to but not sure if I can. The other weird thing is I have both cable box and dvd player connected via digital coaxial and yet the audio is only messed up on tv when dvd player is selected.
post #15 of 17 Old 08-16-2013, 03:03 PM
jautor's Avatar
Liked: 777
Most AVRs (until very recently) would not convert digital sources to analog for Zone2 output. So you're very likely listening to a different signal path. If you're controlling volume with the TV, you also need to make the Zone2 output "fixed" instead of variable if you can. You say that you've connected the DVD player via digital - are you sure? I'm surprised you get any audio at all on the zone2 output.
jautor is offline
post #16 of 17 Old 08-16-2013, 08:17 PM - Thread Starter
Yeah. Oddly the cables from connected to room 2 out carry both signals but the dvd is VERY weak. I tried your suggestion and connected to aux and it worked. it's a little bit of a pain since I have to keep switching audio for the dvd but since my projector is dead and I am looking for a new one I only use the second tv so I wil manage for now. Hopefully I can upgrade my avr. Any suggestions on a good one?
post #17 of 17 Old 08-17-2013, 01:33 AM
jautor's Avatar
Liked: 777
Anything current. AVRs have had a huge increase in functionality in the last few years. Get one with Ethernet / Network support so you have Internet streaming services and IP / "app" controls. Room correction systems are built-in to a lot of models as well, which is probably the "step up" feature worth looking at.
Jeff
jautor is offline
Reply Home A/V Distribution
Sherwood , Projectors
