Looking for recommendations for 5.1 or 7.1 receivers with IP or serial control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-02-2012, 09:02 PM - Thread Starter
hedg12's Avatar
I'm still in the planning stages for my AV/automation system and have pretty much decided that I'm going to use multiple AV receivers to switch and distribute media to my zones that have video. Since my overall budget for automation/AV is shrinking (the wife think new flooring & paint are more important - imagine that) I'm looking for 1 receiver in the sub $1500 range for the family/media room & 3 in the sub $500 range (the cheaper the better) for the bedrooms (for now - I'll add more as finances allow.) Zone 2 on the bedroom receivers would be ideal, but that may be asking a lot in that price range.
I'm still not sure exactly how I'm going to control everything, but I do know it will involve tablets of some kind and a PC based software solution (I'm using openremote now and may well stick with it, but I'm looking at alternatives.) I'll also have conventional hard button remotes for media and lighting control. I need the receivers to have either IP or serial control so I can have feedback on the tablets and absolute volume control from the automation system. Any suggestions?
hedg12 is offline
post #2 of 2 Old 09-03-2012, 02:30 PM
Dean Roddey's Avatar
Quoted: 410 Post(s)
Liked: 342
From the list that we support, there are some fairly obvious choices for the main one from Denon, Yamha, Pioneer, or Integra. They have a range of serial/IP controllable receivers, probably Denon and Integra have the most choices..
For a lower priced one, the Marantz SR5005 is a potentially good one. It has a good control protocol that seems solid, and it isn't expensive.
This all of course depends on whether they have the A/V features you need.
Dean Roddey
Chairman/CTO, Charmed Quark Systems, Ltd
www.charmedquark.com
Dean Roddey is offline
Reply Home A/V Distribution
Denon , Marantz , Yamaha , Pioneer , Marantz Sr5005 Audio Video Receiver Black , Receivers Amplifiers
