Fireblock and cable chase? - AVS Forum | Home Theater Discussions And Reviews
Old 09-08-2012, 04:19 PM - Thread Starter
drjaymez's Avatar
I'm running a cable chase in my front closet between my crawl and attic to run...well a bunch of stuff. several runs of cat6, maybe some speaker wire, maybe some low voltage. At the moment, I will probably use it for a POE IP camera. It is a ranch home. Older, built in the 60s. From a fire standpoint, I know I should look at my local code, and I will, but what should I use for a chase? I know they make PVC that is rated for fire (like boiler exhaust for example), but normal PVC is not. Does that not matter if I am not in a chimney chase?
Also, what should I put on each end? Should I just caulk with firestop calk around the pipe and the cables (a PITA if I have to run something else), or what?
Would I be better off running electrical conduit? metal? plastic? I'm thinking I'll use 2 pieces of PVC for easier installation and join them in the closet with PVC cement.
I'm especially interested in any safety related tips.
drjaymez is offline
Old 09-08-2012, 07:21 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Use flexible PVC cable conduit, to hold the cables. The conduit penetrations should be caulked with fire rated caulk. You can save some money and use rigid non-metallic electrical rated gray PVC.
The open ends of the conduit can be filled with flexible putty, available as a brick at HD/Lowes, called duct seal, if you need it.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 09-09-2012, 08:01 PM - Thread Starter
drjaymez's Avatar
drjaymez is offline
