Audio Distribution- Possibly Sonos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-17-2012, 01:11 PM - Thread Starter
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
I just purchased a new home (to me) and want to install a home audio distribution. I will be installing in ceiling speakers and will have 4 zones. I really like the Sonos connect amps but I would need 4 of them. I am only looking to stream Pandora and iTunes. Is there an alternative for maybe a litte cheaper? Sonos just looks to be the easiest route as far as I can tell.
Denon X4200W
Chane's A5rx-c's Towers
Chane A2rx-c Center
Chane A1.4 Front Heights
EMP Bipoles Surrounds
Epson 2045 with 125" Elite Screen
dago52 is offline
post #2 of 5 Old 09-17-2012, 03:24 PM
jautor's Avatar
Quoted: 1227 Post(s)
Liked: 787
Depends solely on how much flexibility you need. If playing Pandora (one stream) in one or more of the zones is the only choice (plus zone on/off), a single Sonos and external amp, powering a speaker selector with volume control would be a cheaper solution... Or two Sonos units both feeding 2 zones each, depending on your usage model...
But yes, for retrofit solutions without local keypads, the Sonos system is absolutely simple. The forthcoming NuVo system would be a competitor, but it's not yet available and therefore we can't do a comparison.
Jeff
jautor is offline
post #3 of 5 Old 09-19-2012, 11:51 AM - Thread Starter
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
Thanks for the reply. I thought about the volume controls and may do that to minimize on the Sonos amps. Maybe I can do bedroom/ bathroom on the same zone with a volume control. And maybe kitchen/ back pation on one zone with a volume control in the kitchen.
Only if Sonos made a multi zone connect amp.
Denon X4200W
Chane A2rx-c Center
dago52 is offline
post #4 of 5 Old 09-23-2012, 11:15 AM - Thread Starter
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
Will I need impedance matching volume controls with the sonos connect amp if I decide to go this route?
Denon X4200W
Chane A2rx-c Center
dago52 is offline
post #5 of 5 Old 09-23-2012, 11:21 AM
jautor's Avatar
Liked: 787
Yes.
jautor is offline
Reply Home A/V Distribution
