can I use PC onboard audio output as source in multi room home audio system? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-25-2012, 03:19 PM - Thread Starter
jqi01's Avatar
Hello, All,
First, thank you so much for any suggestion you can provide to me. Also thank you for your time to read this post even if you do not have any comments.
I have an existed 2 story house. I plan to use HTC middle level whole house audio system. MC-66
http://www.htd.com/Products/mid-level-whole-house-audio
it has 6 control source and 6 zone amplifier. I plan to use two TVs audio out and two PCs speaker out as source. The PC has onboard audio out, It can be configured as 7.1 output. The PC also has Logitech Z-5500 5.1 Speaker System as speakers. My question is can I setup my PC to 7.1 and use 5.1 to drive the logitech Z-5500 and the other two side speaker output connect to MC-66 control source? Is the output good enough for control source? How can I use the PC audio output as source to send signal to whole hourse speakers?
The PC is over-the-air HDTV.
PS, My PC is MSI 785G-E53, AM3, the audio information I could found is as follow:
Audio
• Chipset integrated by Realtek® High-End Audio chipset
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
Thank you so much for your time and help.
jqi01 is offline
Reply Home A/V Distribution
