Xantech Digi-5 Alternative - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-25-2012, 03:21 PM - Thread Starter
iolaus's Avatar
Does anyone know of an alternative to the Xantech Digi-5 distributed audio system?
I've got the Xantech D5RH installed now but bugs in their firmware make controlling some aspects of the system via RS-232 impossible. Additionally, the Xantech D5KP Keypads seem to have very poor quality control with button and backlight problems.
I'm looking for a system with the following features:
  • Ethernet connectivity between controller and keypads
  • Amplification at the keypad
  • Two way communication via RS-232 or Ethernet
  • Local source capability (preferably digital input)
  • Digital audio input on hub
  • Paging and/or intercom system
Any suggestions would be very much appreciated!
iolaus is offline
post #2 of 4 Old 09-25-2012, 07:16 PM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
There are Digi-5 products from Aton as well - note that the Digi-5 stuff is now all owned by the Core Brands group (formerly the AVC group, still part of Nortek). They do appear different - I don't know how much stuff they shared under the covers (don't recall if this was developed before everyone got bought by Nortek).
http://www.atonhome.com/Digital_Audio_Router.html
The Aton doesn't seem to have any external control methods other than the keypad and IR (at the keypads), so this may not be a step in the right direction... But it does meet the rest of the things on your list, well, except:
[*] Ethernet connectivity between controller and keypads
Note that these systems are Cat5e connected, and use RJ45 jacks for termination, but they are NOT Ethernet in any way...
Jeff
jautor is offline
post #3 of 4 Old 09-25-2012, 08:54 PM - Thread Starter
iolaus's Avatar
Jeff
Thanks Jeff,
I have looked at the Aton stuff but had to rule it out because of the lack of a 2-way control mechanism. As to the ethernet connectivity issue I simply meant ethernet cable (ie. cat5, cat5e, cat6) and not the actual ethernet protocol.
iolaus is offline
post #4 of 4 Old 09-26-2012, 07:28 AM
jautor's Avatar
Liked: 832
That's what I thought, but we see way too many folks get confused by that terminology, so my comment was as much a note to anyone else reading as it was a double-check of your understanding... smile.gif When I talk, I usually call it "ethernet cable", too - but when writing on the forum, I always call it "category" or "Cat5e" to avoid potential confusion.
jautor is offline
Reply Home A/V Distribution
