My structural wiring closet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-01-2012, 11:27 AM - Thread Starter
Andrew911tt's Avatar
After being in my house for about 3 years and many different phases I think I am finally done with my structural wiring closet. The house was built in 1972 and is 1089sqft. This is in the office (center-ish part of the house) and started with a blank wall in the closet with no cables run anywhere. My lovely wife and I ran every cable up the wall and through the attic.
I have at least one Directv line, one Cable TV line, and 2 Cat 6 runs to each room.
I have the power panel (bottom right) run to the outlet underneath and then plug that into a UPS so if the power goes out I can run for at least an hour or longer if i turn some stuff off.
Andrew911tt is offline
post #2 of 12 Old 10-01-2012, 04:10 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Looks great, well done! Pulling power from the inlet below and attaching the UPS is great - I did the same thing and it helps prevent all kinds of hiccups for momentary glitches.
Only issue I see is if you put the door on, having the wireless router inside is going to be an issue for wireless reception. I placed mine outside and arranged a pass-through for connectivity.
Jeff
jautor is offline
post #3 of 12 Old 10-01-2012, 08:33 PM - Thread Starter
I have a wireless access point another place in the house that I use most of the time. When I put the metal cover on I expecting it to become a faraday cage but I only dropped one bar
egnlsn likes this.
post #4 of 12 Old 10-02-2012, 12:47 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
Hmm... looks like there is a splitter that is a bit crooked - yuck - gross. JUST KIDDING! smile.gif It looks very tidy - which I am very much in favor of.
Regards, Frederick C. Wilt
fcwilt is offline
post #6 of 12 Old 03-11-2013, 08:45 PM
mykq32's Avatar
Clean look, how did you attach the patch panel to the enclosure? I'm about to do the same but with a 24 port patch panel from mono price. Not sure it's feasible without fabricating something to attach it.
mykq32 is offline
post #7 of 12 Old 03-12-2013, 06:16 AM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
No, really I see you took your time and thought everything out. Nice job.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #8 of 12 Old 03-12-2013, 12:32 PM - Thread Starter
I am actually getting my new router today a TP-Link TL-ER6020. So after I move things around to fit that in I will take more pictures.
I used self tapping metal screws and mounted the "holder" directly to the right side frame. From the pictures it does not look like the 24 port have the "holder." Maybe you should use 2 12 ports patch panels. But remember it doesn't sit correctly if you run all 12 cables from one side.
post #9 of 12 Old 03-12-2013, 01:29 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
That D89 bracket usually ships with the 12-port patch panel.
The Monoprice 24 port patch panel is designed to be mounted in a 19" rack, not a low-voltage enclosure.
If you want to mount a 19" rack-mount device to a wall, you can buy a wall-mount rack or bracket.
You could also consider a small floor standing or wall-mount rack enclosure, near the LV enclosure.
Here are a couple relevant residential patch panel and enclosure threads.
http://www.avsforum.com/t/1401721/please-recommend-12-port-patch-panel-cat5e-6-question
http://cocoontech.com/forums/topic/13756-my-1927-bungalow-home-structured-wiring-project/
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #10 of 12 Old 03-12-2013, 01:57 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Leviton offers some patch panels, for LV enclosures. This 24 port cat6 unit costs $200.
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=476TM-624&section=39641&minisite=10251
Neurorad is offline
post #11 of 12 Old 03-12-2013, 09:08 PM
mykq32's Avatar
Thanks for the replies. I'll look into these.
mykq32 is offline
post #12 of 12 Old 03-12-2013, 11:27 PM - Thread Starter
Here are more pictures
Networking equipment is:
Motorola SurfBoard SB6141
TP-Link TL-ER6020
Cisco SG200-08
Amped Wireless AP20000G (not in closet)
Reply Home A/V Distribution
