Sound issue with AVR-1612 & HDMI Matrix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-03-2012, 09:56 AM - Thread Starter
EpicVegas's Avatar
I've got a Denon AVR-1612 receiver and a Monoprice 4x4 HDMI matrix switcher.
Here is how my setup is currently PC > HDMI > Matrix > HDMI > AVR > HDMI > Projector.
It works great, but when I switch to another source in the switcher say PS3 and then back to the PC I loose the PC's audio...
When I go to playback devices on the PC is sees the Denon but says "not connected"
I've tried powering off and on the AVR but the PC still dossnt connect to a AVR.
Only after restarting my PC will it detect the AVR again.
Any suggestions?
EpicVegas is offline
post #2 of 2 Old 10-03-2012, 01:47 PM
jautor's Avatar
Quoted: 1309 Post(s)
Liked: 836
Most likely your PC / video card is not handling the "hot plug" event(s) properly, so when devices are disconnected from the HDMI chain, it gets confused.
Adding an HDMI Detective between the PC and the matrix to keep the EDID from changing or disappearing might fix it. Might take some experimentation...
http://www.gefen.com/kvm/dproduct.jsp?prod_id=8005
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
Reply Home A/V Distribution
Denon Avr 1612 Receiver
