Best Wifi/ network enabled receiver with multi room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-07-2012, 05:02 PM - Thread Starter
rkillah1123's Avatar
I'd like to run a small system, about 8-10 speakers though out the main portion of the house... Music streaming off a media server in a centralized location, where this reciever will be.
What's my options?
I want something that can be controlled by an iPad, or phone... Are there any or something that I could use to control it from the living area...
Maybe run an Ir cable to the receiver?
Thanks for any replies!
rkillah1123 is offline
post #2 of 5 Old 10-07-2012, 05:04 PM - Thread Starter
Do I just need a reciever with an Ethernet input?
And maybe run a couple power amps along side it?
post #3 of 5 Old 10-07-2012, 06:16 PM
HCCDesignGuy's Avatar
This is a great option: http://integrahometheater.com/model.cfm?class=Receiver&m=DTR-70.4&p=i
Denon also has a good option however I s=don't normally recommend them simply because they tend to have HDMI socket problems (they just use low grade components). I'm not saying that Integra uses high-end components but I can say they are less problematic.
Other idea would be to use a traditional distributed audio system and surround sound receiver for the surround sound instead of trying to task the whole project from a single component.
HCCDesignGuy is offline
post #4 of 5 Old 10-07-2012, 07:31 PM - Thread Starter
That's kinda where I'm leaning towards is a full distribution system, I was weighting my options.
As far as controlling a distributed system would I be better off getting an automation controller or running it from a pc? I want the ability to control with a mobile device like an iPad.
That's why I had asked about the network capability.
Or could I use a reciever like you posted and run a couple power amps on top of that?
post #5 of 5 Old 10-09-2012, 01:58 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
look at sonos, you can get as many zone as you wish and combine rooms to a single zone if you like. built in amps and music streaming capability.
ifor is offline
Reply Home A/V Distribution
