composite video over coax - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-11-2012, 12:56 PM - Thread Starter
TheUser005's Avatar
I like to send composite video (no audio) from basement to another room in the house over an existing RG6 coax cable in the house. I am not trying to send audio, since it's only video, can I do following?
source Composite OUT --> RCA-to-F connector <--existing coax--> F connector-to-RCA ---> TV composite IN ?
Basically I am trying to use my existing coax wire to send video from my security system DVR unit to a room. I tried above but I get no signal, what am I missing? I am thinking modulation is not necessary since I don't care about audio.
TheUser005 is offline
post #2 of 10 Old 10-11-2012, 01:01 PM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
Yep, that should work. As long as your using a composite input on the TV, not an RF input expecting a modulated signal.
Is the coax line "dedicated" to that run - meaning it's not going through splitters or otherwise carrying CATV service?
Might try it with a TV in the same room just to make sure you're sending a signal at all from the camera.
Jeff
jautor is online now
post #3 of 10 Old 10-11-2012, 01:50 PM - Thread Starter
TheUser005's Avatar
Jeff
Thanks. Actually if I hook up a good old RCA cable from DVR to a TV, it works fine. But when I use the Fconnector-to-RCA adapters on each end, I get no signal to the same TV. Another thing was going to try was cut off the coax connectors on each end and connect RCA connectors and see if that work.
post #4 of 10 Old 10-12-2012, 08:41 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
I think you need to find the splitter and bypass it. It seems unusual to have a line run uninterrupted from one room to another. Most in place Coax goes back to a common point.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 10 Old 10-12-2012, 12:45 PM - Thread Starter
TheUser005's Avatar
Actually all coax wires from all rooms are coming to a central wiring panel but I am not going through any distribution module, etc. Last night, I did a little test where I used F-connector-to-RCA adapter to both ends of a 6ft coax cable and used that to connect DVR's composite monitor output to a TV's RCA input. It worked fine, so I confirmed that I can use coax to carry composite video.
Then, I connected same F-connector-to-RCA adapters to the coax cable going to a room on 2nd floor (about 40-50ft length) and hooked up to DVR's monitor out and same TV, no signal !
I believe coax is fine because I tried sending Dish Network signal over it and it works fine. Could length be an issue?
post #6 of 10 Old 10-12-2012, 05:32 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Most security DVRs use a BNC connector for ALL video connections. The only RCA connectors are for audio.
I run one of my cameras from the camera to my cabling center in my basement, to a closet upstairs, then from that closet to the room where my DVR is, all on existing cabling, with no issues.
CIAO!
Ed N.
egnlsn is offline
post #7 of 10 Old 10-13-2012, 05:58 AM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
See post #4.
cshepard is offline
post #8 of 10 Old 10-13-2012, 08:36 AM
SAM64's Avatar
Liked: 78
No.
Composite video is meant to be transmitted over 75 Ohm coax cable...you've confirmed what the designers intended.
As mentioned, chances are there's some device in line that is not allowing the base band signal through. You can easily confirm this with a multimeter.
SAM64 is offline
post #9 of 10 Old 10-13-2012, 08:51 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Splitters that go down to 5Meg will still pass part of a baseband video signal. It's a rather messed up picture, as I think sync isn't all there, but there is a picture.
CIAO!
Ed N.
egnlsn is offline
post #10 of 10 Old 10-13-2012, 08:51 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Originally Posted by cshepard View Post
See post #4.
See post #5.
CIAO!
Ed N.
egnlsn is offline
Reply Home A/V Distribution
