Video Controller: RG6 4x4? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-11-2012, 03:57 PM - Thread Starter
DGreekVA's Avatar
Hello all,
I need to switch two video sources to three different displays using existing RG6 Quad Shielded cabling. The signals are all RF, converted by each display. The controller needs to be IR controlled so it will work with my whole home automation controller.
Any suggestions? In my last home I had an Elan 880 video controller which did this same function. I'm hoping to be brand agnostic here and be focused on the quality of the device and it's function, I only mention Elan since that may be a baseline for all of you WRT functionality desired.
Thanks!!!
DGreekVA is offline
post #2 of 2 Old 10-11-2012, 05:58 PM
jautor's Avatar
Quoted: 1225 Post(s)
Liked: 787
What are the sources?
If they're outputting RF, and they're not at the same frequency, a simple combiner would do the trick.
jautor is offline
Reply Home A/V Distribution
