Does this device exist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-18-2012, 02:13 PM - Thread Starter
I need a super simple, inexpensive audio streaming device that has either analog (RCA), toslink or coax digital audio inputs and either built in wifi or ethernet that can be connected to a wifi gateway to create an audio only stream that can be monitored using any wifi device with a web browser over a network. For simplicity sake think about it as a slingbox minus the video portion and the control portion...no control is needed for the source...just the encoding and streaming of audio. Ideally this device would be bulletproof simple and cost less than $100 at retail. Other requirements would include minimal lag between the audio input and decoded audio stream. Also..I am aware that there are many ways to do this with a computer but I am looking for a stand alone device.
skdanser is offline
post #2 of 8 Old 10-18-2012, 04:52 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
Apple Airport Express. Will accept a stream from an iOS device or iTunes on a Mac/PC using AirPlay.
There is a 3rd party utility called AirFoil for Windows that can stream an PC audio content to an Airplay device as well.
Assuming you wanted the "receiver" part of a streamer, not an actual streamer. A standalone, self-contained streaming device is different, and the best solution now is the Sonos:Connect.
Jeff
jautor is offline
post #3 of 8 Old 10-18-2012, 06:28 PM - Thread Starter
I am looking for a device that will work stand-alone...without the use of a computer. I do want the streamer side of the equation not the receiver side. The cost of a Sonos is way more than the cost of a slingbox. I am looking for something in the sub $100 range.
skdanser is offline
post #4 of 8 Old 10-19-2012, 12:11 AM
jautor's Avatar
Liked: 780
That's really not relevant. Two very different products. Yes, they both have chips and an Ethernet jack and a power supply.
Good luck. A used Squeezebox or Roku Soundbridge would be your best bet. But they won't have the Internet "services" of a current-generation product. The Roku was excellent (I use my Soundbridge Radio daily) - and still streams Internet Radio very reliably. Both of those products would still require a PC for serving a digital library.
Exactly what do you want to "stream" to this device? I'm afraid that if you want more than Internet Radio - meaning Pandora, Spotify, Sirius/XM, etc. you're either going to need to use an iPod Touch + Airport Express, or save up for a Sonos...
Jeff
jautor is offline
post #5 of 8 Old 10-27-2012, 09:30 AM
betawax's Avatar
betawax is offline
post #6 of 8 Old 11-28-2012, 08:57 PM - Thread Starter
I am not looking to stream someone else's content off the internet...I want to stream my own content over the internet without a computer. A simple device with an input on one side that takes audio from any source and an ethernet jack on the other side that outputs a tcp/ip bitstream that can be "tuned in" by a device (computer/iphone/ipad/etc) on the same network.
skdanser is offline
post #7 of 8 Old 11-28-2012, 09:47 PM
jautor's Avatar
Liked: 780
http://www.barix.com/Instreamer/301/
jautor is offline
post #8 of 8 Old 11-28-2012, 10:00 PM - Thread Starter
This is exactly what I have been looking for...now if I can only find one that is $100!
skdanser is offline
Reply Home A/V Distribution
