Distribution Amp w/ Volume Controls in Front and Cat5 to Wall VCs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-27-2012, 10:21 PM - Thread Starter
hal1234's Avatar
Are there any ~6 zone amps that have nice volume knobs (i.e. not screwdriver gain pots) in front but also allow for remote volume adjustment via cat 5 (or any hardwiring) from wall volume controls? Don't care about IR nor for $$ complex whole-house systems.
hal1234 is offline
post #2 of 5 Old 10-28-2012, 05:04 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Slider?
http://ecx.images-amazon.com/images/I/41ul7UGk1wL._SL500_AA300_.jpg
Speakercraft?
http://a248.e.akamai.net/origin-cdn.volusion.com/uzgz5.ycjv9/v/vspfiles/photos/SC%20VSR-100-2.jpg
Digital?
http://ak.buy.com/PI/0/300/205839827.jpg
Those VCs are inline with the speaker cable, just a routine swap of existing VCs. Using a category cable will require motivation, time, and skills, AFAIK. You might consider Xantech for something like that.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #3 of 5 Old 10-29-2012, 01:30 PM - Thread Starter
hal1234's Avatar
Thank you for the suggestions. So let's say I went with the Speakercraft VC...is there a 4 or 6--zone distribution amp out there where I can wire this VC to it (via the Cat5 wires)...I have both Cat5 (home run) and 4-conductor speaker wire to each zone.
hal1234 is offline
post #4 of 5 Old 10-29-2012, 03:25 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Found the Speakercraft VSR-100 manual, but I think it's discontinued.
http://www.speakercraft.com/download2.php?id=277
I thought that was only in-line with the speaker analog signal, but it looks to be wired via cat5 as well - for IR control.
post #5 of 5 Old 11-07-2012, 08:57 PM - Thread Starter
hal1234's Avatar
Thanks for all the help. I ended up going with the HTD MCA-66 and it worked out really well.
hal1234 is offline
Reply Home A/V Distribution
Cat5 Rack 1u
