Cable TV Distribution Amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-06-2012, 05:49 PM - Thread Starter
mfrey0118's Avatar
Came across one during an estate clean out. I have no idea if amplifying my cable signal is something that would improve PQ at all. I've never owned one and I have no experience with them.
I have Comcast Xfinity.
Any input is appreciated.
60" 1080p 3D Plasma Panel
3D 1080p Blu-Ray player
4K 7.2 Channel AVR
mfrey0118 is offline
post #2 of 6 Old 11-06-2012, 07:34 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
For digital channels or HDTV channels, unless you're experiencing drop-outs (picture freezes or macroblocking), it won't do anything for picture quality.
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 6 Old 11-07-2012, 09:33 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
It might actually cause problems that jautor mentioned. Too much signal is just as bad as too little.
CIAO!
Ed N.
egnlsn is offline
post #4 of 6 Old 11-07-2012, 10:18 AM - Thread Starter
mfrey0118's Avatar
Jeff
What's macroblocking? The image breaking down into big square blocks during bright fast motion scenes on a 1080i signal? I have that.
This amp has an adjustable gain.
4K 7.2 Channel AVR
post #5 of 6 Old 11-07-2012, 11:02 AM
jautor's Avatar
Liked: 852
Yes, but if it's happening on fast motion only, it may just be the limits of the broadcast you're receiving. Dropouts from weak signals will appear as blocks of the wrong colors, garbled areas of the screen and so forth.
If your set-top box has a diags screen that can show the signal strength, go by that. You could insert the amp at the lowest gain, and raise it. As long as you don't overdrive the signal as egnlsn mentions, it won't hurt anything. But unless you're getting dropouts/blocking due to a weak signal, it won't help either.
Since you already bought the amp, go ahead and insert it, see what you get. But do keep the gain on the low side - you should shoot for a +3-6dB gain after accounting for your splitter losses.
Jeff
egnlsn and mfrey0118 like this.
jautor is offline
post #6 of 6 Old 11-08-2012, 05:43 AM - Thread Starter
mfrey0118's Avatar
Cool, thanks for the info.
4K 7.2 Channel AVR
Reply Home A/V Distribution
