Distribution Amp Install - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-10-2012, 02:28 PM - Thread Starter
hardcorecamraman's Avatar
OK, I have a slight problem. I have a distribution amp hooked up to my theater setup but I am not sure where to mount it. I have some extra cable I NEED TO HIDE!!!
So, two situations:
First, I am looking for suggestions as to how and where to mount the amp
Second, I am looking for some suggestions on dealing with extra cable.
Thanks Guys!
hardcorecamraman is offline
post #2 of 5 Old 11-10-2012, 03:01 PM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
The world is a pretty big place in which you can hide it. We have no idea what you're looking at, what your options are, or anything. Wherever you do place it, make sure it has adequate ventilation, won't get excessively hot, and is safe from the elements.
Just coil up the excess cable in a loop about the size of a c.d. and stash it wherever you want.
CIAO!
Ed N.
egnlsn is offline
post #3 of 5 Old 11-10-2012, 03:20 PM - Thread Starter
It is one of those amps with the holes for screws and I am just looking to see what other's have done that have distribution amps.
post #4 of 5 Old 11-10-2012, 04:27 PM
Neurorad's Avatar
Quoted: 232 Post(s)
Liked: 145
My 'local source audio amp' is recessed into a 4-gang junction box, behind a Decora plate, behind a wall-mount TV.
Do you have a TV? Perhaps it can be mounted to the back of it.
What type of 'distribution amp' is it? Model #, link, and/or pic would be a minimum.
Are you talking about a coax cable distribution amp?
I'd hide it behind the TV, mounted with double sided tape or Velcro. Or, at the other end of the cable.
And, I'd hide all cables behind drywall. If coax, I'd use keystone connectors and wallplates. Hide the Wallplates behind the TV, or other furniture.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 5 Old 11-11-2012, 09:41 AM
Neurorad's Avatar
Quoted: 232 Post(s)
Liked: 145
Industrial Velcro from Home Depot
egnlsn likes this.
Neurorad is offline
Reply Home A/V Distribution
