3 tv hdmi tv using 3 balun's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-11-2012, 08:19 PM - Thread Starter
cwichlaz's Avatar
Hello,
I'm currently working on a project for my local church where they are installing 3 Vizio model M550VSE. We are wanting to use a desktop/laptop to run a power point sermon and to run DVD player thru the computer. The plan is to use 3 Stellar Labs model # 33-12570 active balun's one to each TV, with a router. Is this possible? What type of router would I need to get? Would I need additional software?
Thank you
Chris Wichlaz
cwichlaz is offline
post #2 of 2 Old 11-11-2012, 10:43 PM
Colm's Avatar
Liked: 94
No, although the product you are considering used Cat 5/5e/6 cable, it doesn't run ethernet. You need to use a HDMI splitter, not a router. The wiring has to be separate of any network wiring. Also, you might be better off using a HDBaseT based product than the one you are considering. It will be more reliable, capable of longer distances at a given bit rate, and only require running one cable to each display.
Colm is offline
Reply Home A/V Distribution
