IR distribution help needed -- isolating two remote receivers - AVS Forum | Home Theater Discussions And Reviews
Old 11-20-2012, 12:58 PM - Thread Starter
cowger's Avatar
Liked: 73
Hi,
I've been struggling with a problem and I'm hoping that people smarter than me can help me figure out a solution.
Here is a picture of a coax-based IR distribution network I have running in my house. I have all my DVRs centralized in one place and use an HDMI switch to send content out to various rooms. Each room with a monitor has an IR receiver which injects the IR onto coax (which has been abandoned for video distribution now; its only use is to distribute IR).
All but one aspect of this (see below) works well; the DirecTV DVRs are all set up to only pay attention to their specific remote; a universal remote in each room can control the HDMI switch remotely and then assume the personality of the appropriate remote.
I have two Onkyo receivers; one upstairs in the TV room and one near the HT to serve that room, housed in the same rack as the DVRs and HDMI switch. Each component in the rack gets a copy of whatever is inserted onto the IR distribution network.
The problem is this: When I send commands to the receiver in the TV room (Onkyo Rcvr #1), the other receiver is getting a copy of that signal and responds as well. Thus, controlling the receiver in the TV room messes up the viewing in the HT.
Any ideas for this? I suppose a brute force way would be to set up a completely separate IR network for each, but I'm hoping for a more elegant solution...
Bryan
cowger is offline
Old 11-20-2012, 01:55 PM
Vyrolan's Avatar
Well...firing from the hip here, but you could have your distribution system not send commands to the Onkyo in the rack. That would prevent it from being controlled in the TV Room. Then setup a separate IR extender from the HT to the rack to allow it to be controlled. You'd have two IR receiver eyes in your HT...one for controlling everything in the rack except the Onkyo, one for just the Onkyo. If your HDMI extender feeding the HT display has IR capabilities (or you change to one that does), you could just use that.
Beyond that, I'm not sure what else you could do...I'm assuming your IR equipment doesn't have any kind of routing built-in or you would just be using that.
I guess you could add a little IR routing piece between the distribution and the Onkyo in the rack. It would default to off so that TV Room doesn't control it, and the remote for the HT would have to be programmed to "enable, send command, disable" for everything. You'd run the risk of someone in the other room sending a command at the same time, and it'd be pain to get it working well for push and hold stuff like Volume control.
Vyrolan is offline
Old 11-20-2012, 06:46 PM - Thread Starter
cowger's Avatar
Liked: 73
Thanks, Vyrolan, for the thoughtful suggestions! I agree that adding a 2nd, completely independent IR network, with a 2nd receiver eye in the HT, is a workable solution.
However, your post got me thinking, and I'm wondering if I could use a diode here to help me... Below is a new diagram with 3 new components in red:
My thinking is this: Split the signal coming from the HT IR receiver, send one side directly to the HT-dedicated components (namely Rcvr #2 and the BR player), and send the other side on to the normal IR network. (BTW, I already tried this w/o the diode, not realizing that the signals from the TV room would crawl right back up the coax network, through the splitter, and over to Rcvr #2.) However, if I could add a diode in that second line, it would prevent signals coming from the TV room receiver from getting to Rcvr #2, yet both sources still make it to all DVRs and the HDMI switch.
The question is whether an inline diode would work and you can block a signal like this or not. Has anyone ever looked at the IR signal after it's injected onto coax? What kind of voltage do they run peak-to-peak? Enough to overcome the 0.7V diode forward drop?
I'll grab a diode tomorrow, solder it (and a ground) between a couple coax connectors, and see what happens...
Bryan
cowger is offline
Old 11-20-2012, 08:48 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
IR over coax is either 5V or 12V signalling depending on the system. Is this one of the Xantech or ChannelPlus systems? If it's a Xantech XtraLink with the IR receivers powered at the zone end, adding a splitter and another CPL18 for the theater side would get you there (no need for the diode)... If it's a ChannelPlus 5V setup powering the IR receivers at the coax panel, I don't think your diode trick is going to work...
jautor is offline
Old 11-21-2012, 07:11 AM
SAM64's Avatar
Liked: 78
I don't see how the baseband data from a receiver can drive an IR LED directly, without the required modulation.
SAM64 is offline
Old 11-21-2012, 09:23 AM - Thread Starter
cowger's Avatar
Liked: 73
It's all Xantech stuff: INJ94 injectors at each zone and CPL94Bs at the rack (equipment) end. I couldn't find what a CPL18 is...
I think you're suggesting that if I rig up the configuration show directly above but without the diode, it should work. If so, I tried that, but Rcvr #2 still gets the Onkyo signals from the TV room, since the coax network acts just like a DC distribution and everything flows everywhere.
Bryan
cowger is offline
Old 11-21-2012, 09:24 AM - Thread Starter
cowger's Avatar
Liked: 73
Sorry, my diagram is very simplified. There are INJ94 injectors in each of the zones, which are powered by 12VDC supplies and this generates enough power to drive all the emitter LEDs. Hope this answers your question...
Bryan
cowger is offline
Old 11-21-2012, 09:28 AM
SAM64's Avatar
Liked: 78
it doesn't...those injectors don't modulate the signal at all.
SAM64 is offline
Old 11-21-2012, 09:38 AM - Thread Starter
cowger's Avatar
Liked: 73
Okay, sorry, then I don't understand the question. "Modulation" to me means bringing the low-frequency IR signal up to TV channel frequencies. My understanding of this IR distribution is that it all runs on baseband and there's no reason to modulate, but I'm clearly missing something...
cowger is offline
Old 11-21-2012, 10:36 AM
SAM64's Avatar
Liked: 78
The signal applied to the IR LEDs is modulated, usually around 38KHz.
The signal from the receiver is baseband...the modulation is removed by the receiver/demodulator.
SAM64 is offline
Old 11-21-2012, 10:51 AM - Thread Starter
cowger's Avatar
Liked: 73
Okay, got it, that's great to know.
So the problem is that I've mis-labeled things in the diagram above. Where I say "IR splitter" it should read "demodulator". And the receivers in the zones should have a "modulator" box shown (which they do have).
cowger is offline
Old 11-21-2012, 12:55 PM
jautor's Avatar
Liked: 780
Ack, I think I grabbed the wrong part #... Ok, with the XtraLink2 setup, you can just buy one more CPL94. Where you have the "DC passing splitter", you split, and place the new CPL94 on a leg to plug your theater-dedicated emitters. I think that will work...
Jeff
jautor is offline
Old 11-21-2012, 02:12 PM - Thread Starter
cowger's Avatar
Liked: 73
Jeff
Ah, I see what you're saying. I'll give this a shot and let you know!
Bryan
cowger is offline
Old 11-22-2012, 11:42 AM - Thread Starter
cowger's Avatar
Liked: 73
Well, believe it or not (and I'm still somewhat shocked myself), my hokey-pokey diode trick works! I implemented as shown below and got all the functionality I was looking for.
Now IR commands from the TV Room don't make it to Rcvr #2 (and the BR player), but commands from either zone make it to the DVRs, etc. biggrin.gif
Here's how I put a diode inline with a short piece of coax:
jautor, I did try out what I think you were suggesting, but unfortunately that didn't work. Here's what I did; the red arrows represent my idea of how TV Room commands were still making it to Rcvr #2:
Perhaps I didn't implement things the way you were thinking, but in any case, it's a happy ending for <$4 of parts from Radio Shack.
Thanks to all who helped me get through this!
Bryan
cowger is offline
