Need solution for 4 "B" speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-26-2012, 07:03 AM - Thread Starter
mikeneedshelp's Avatar
I have a 5.1 pioneer receiver, about 5 years old, pretty straightforward receiver, does the trick. We have the 5.1 hooked up for surround sound in our den, and we currently have 2 outdoor speakers on my deck hooked into the B speaker input.
I want to add another two speakers outdoors. I'm out of speaker inputs though. I'm looking into getting another receiver, but only to accomodate this need. I'm not looking to blow it out cost wise - we barely use the indoor speakers as it is. We actually use the outdoor more, and I love the way they sound. Need to add two more, ground speakers, down on the lawn.
I'm having difficulty sorting receivers by # of "B" inputs. I don't think I need one of those whole house receivers - or do I? Do those have 5.1 too, for one room?
Am I better off just having a workaround like a splitter? Not that fired up about having to manually click over if I do that, and not even sure that would work.
Any suggestions here? Anyone know of a reasonably priced receiver w/ 4 B speaker inputs?
mikeneedshelp is offline
post #2 of 2 Old 11-26-2012, 08:49 AM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
You can get a small impedance-matching speaker selector to allow you to safely (won't overdrive the receiver) hook up two pairs to those "B" outputs. RadioShack has one, and there are many available...
Jeff
jautor is offline
Reply Home A/V Distribution
