Zone 2 and 3 connections using to receivers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-27-2012, 12:18 PM - Thread Starter
degiver's Avatar
Looking for guidance on zone 2 and 3 setup.
I plan to use my new TX-NR717 (7.2) as my pre-amp and my old TX-SR605 (5.1) as the amplifier for zones 2 and 3. The 717 has pre-amp outs for zones 2 and 3 as well as a powered zone 2. The 605 has a powered zone 2.
I’d like to have as much flexibility in source selection by zone a s possible. I am running 5.1 in the main room using the 717, but would like to leave the remaining 2 channels free in case I decide to expand later to 7.1.
What I was planning to do is zone 2 pre-amp out from the 717 into an analog input on the 605 (maybe CD). Then use the powered zone 2 on the 605 to power zone 2 speakers. For zone 3 speakers, I planned to use the front (R & L) channels on the 605.
Is there a better way to hook this up using a three zone set up with these two amplifiers?
I appreciate your expertise. Thanks
degiver is offline
post #2 of 4 Old 11-27-2012, 01:00 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
The issue with this setup is going to be control... You'll have to manually turn on the 2nd AVR in order to use zone2/zone3, which makes it a pain to use - especially since it defeats the "app"-based remote control potential of the NR717.
Since the 717 has a powered zone2, and you're not using the 7.1 capability currently, I'd suggest selling the 605 and buying a simple 2-channel auto-on/off amp like the AudioSource AMP-100 for your zone3 (~$100). Use the powered zone2 for now - if you expand to use 7.1 later, buy another AMP-100 to take over the zone2 role.
Jeff
jautor is online now
post #3 of 4 Old 12-11-2012, 06:57 PM - Thread Starter
degiver's Avatar
This has been VERY helpful. Thank you. What about this? I have a TX NR717. For zone 3 I plan to wire the zone 3 pre-amp out to a Onkyo M-282 (line in) audio in and M-282 to zone 3 speakers. I'd like to add a powered sub in zone 3. Is it possible to use the M-282 audio's (R & L) out to send a signal to the powered subwoofer's (R & L) line in?
degiver is offline
post #4 of 4 Old 12-11-2012, 08:41 PM
jautor's Avatar
Liked: 780
Yes, that should work fine. That's a larger amp than the one I suggested, but it's got triggers and auto-on/off, so it's a good answer.
Depending on your choice of subwoofer, it may have speaker-level inputs that can be looped in-line with the L/R speakers from the amp output. Either line or speaker-level will work - whichever works better with your wiring setup.
I have a powered sub in one zone, doing essentially the same setup - I used a MuxLab audio-over-cat5 balun to feed audio to the powered sub, as it's placed nowhere near the speaker wiring, but I had plenty of cat5 lines handy.
Jeff
Reply Home A/V Distribution
