How many Sonos Amps. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-03-2012, 06:49 PM - Thread Starter
Mspears02's Avatar
I am about to move into a new house and am trying to verify a setup recommendation.
I have control4 being installed with a C4 audio matrix
Niles 6 Zone amp
Niles speakers in 6 zones
Sonos Play 5 x2
Sonos Play 3 x2
If I want to listen to the exact same thing say MOG on all zones using Sonos my questions are.
How many if any Sonos amps do I need?
How do they integrate into the system? Do they connect to the audio matrix or elsewhere?
If I want what I am watching on TV to be distributed to all sources does this change anything?
I know these are probably simple questions but I don't know the answer. Thanks for your help.
Mspears02 is offline
post #2 of 8 Old 12-03-2012, 06:52 PM - Thread Starter
Mspears02's Avatar
Q
post #3 of 8 Old 12-03-2012, 07:16 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
If you're paying for a Control4 installation, these are really questions the dealer/integrator should be answering for you...
I don't know why they'd be using a Play unit instead of a Sonos:Connect for a source into a Niles amp / Control4 audio router.
A Sonos unit for a distributed audio system is a "source". You can listen to any source in any room. The number of sources you need will depend on how many different things you want simultaneously. A good rule of thumb is one per adult/teen in the household, and then adjust from there. Meaning, if there's only two people in the house, you probably don't need the ability to listen to more than 2 things at a time...
You can distribute any analog audio source, but you have to get that audio to where the system resides. Sonos units can help with this, but without knowing all the system details / layout, don't know if this will be easy or hard. Again, if you don't understand how all this integrates, you really need to have a conversation with the integrator, before you fork over money for something that doesn't meet your expectations.
Jeff
jautor is offline
post #4 of 8 Old 12-03-2012, 07:24 PM - Thread Starter
Mspears02's Avatar
Jeff,
Thanks for the help. Let's just assume for now I am verifying what my installer is telling me....
They aren't using anything yet..
The play3 and play5 I have at my curren t house with a simple setup. My question still is do I need more than one Zp90 or zp120"
Tell me what else you need to know and I will provide. Thanks for helping me out
post #5 of 8 Old 12-03-2012, 07:31 PM
jautor's Avatar
Liked: 777
If you're trying to build a whole-house audio system, the Sonos:Play units aren't really much help. I suppose you could use them as sources using the headphone jack, but that will be more difficult to control (and isn't really meant for that purpose).
You don't need any Connect:Amp (zp120) units, the Connect (Zp90) is the correct choice. Quantity is as I described above. I think you could use one of your Play units to send TV audio back to the Connect unit(s), if they work like the rest of the Sonos gear...
jautor is offline
post #6 of 8 Old 12-03-2012, 07:38 PM - Thread Starter
Mspears02's Avatar
Jeff.
I just want to be able to listen to the same thing at the same time on all of my Sonos play3/5 and my miles in ceiling speakers.
post #7 of 8 Old 12-03-2012, 07:41 PM
jautor's Avatar
Liked: 777
Then one. And don't know why you'd need the Control4 pieces at all...
jautor is offline
post #8 of 8 Old 12-03-2012, 07:59 PM - Thread Starter
Mspears02's Avatar
Video matrix home automation
Reply Home A/V Distribution
