hook up to pioneer vsx 50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-06-2012, 07:30 AM - Thread Starter
wowow13's Avatar
I'm hoping someone can help me here as I'm trying to figure out something but can't find answers
i have a pioneer vsx 50 , with the output going to a projector (hd20)
i have a pc hooked up to one of my inputs via HDMI ( so it plays video and audio through my speakers out of my receiver and video to the projector)
I'm trying to run a karaoke/dj program out of the pc ( virtual dj) which plays fine audio and video ..
my problem is adding a microphone to the equation
i have contacted the virtual dj forums but they keep saying to hook up an external set of speakers which i don't want to do
my question is , is there a way to have the video from the pc input play on the screen and then simultaneously play audio from another source through the recieveer i.e. zone 2 ?
I'm thinking in theory i can have the pc input show the screen and then play sound via rca cable to the zone 2 ...will that work ?
hopefully i made sense and didn't confuse anyone as much as i am lol
wowow13 is offline
post #2 of 4 Old 12-06-2012, 03:18 PM
jautor's Avatar
Quoted: 1225 Post(s)
Liked: 787
Did you try hooking up the microphone to the PC? You need a mixer to blend the audio and the microphone - if you're using a karaoke software package, I'd assume it would have the functionality already included (although your PC should be able to do it on its own) - so the mixed music + voice would come out the HDMI output...
jautor is offline
post #3 of 4 Old 12-07-2012, 08:55 AM - Thread Starter
wowow13's Avatar
so you mean run my karaoke program i.e. virtual dj for the video/songs
and then use the internal control for the mic and the sound will work for both ?
wowow13 is offline
post #4 of 4 Old 12-07-2012, 09:14 AM
jautor's Avatar
Liked: 787
That would be the first thing to try, as it's free!
jautor is offline
Reply Home A/V Distribution
