Zone 2 setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-07-2012, 07:16 PM - Thread Starter
pwinters24's Avatar
Can somebody help me just confirm what I'm thinking of doing will work. Just want to make sure before I start something only to find out I'm on the wrong track. My end goal is to have 5.1 in the living room, powered zone 2 that runs to multiple speakers around the house and outside. Ability to watch a movie or gaming in the living room and stream from a PC or pandora to zone 2. I don't need separate sources to zone 2, whatever is going to zone 2 would play to all speakers in zone 2.
I'm thinking my setup would be as easy as a Denon 1913 with the powered zone 2 running to a Niles SSVC6 speaker selector which gives individual volume control, albeit I'd have to control each separate volume at a central location. I figure I'd have a standard volume for each location and just either have each location on or off.
Will this work like I think it will? Thanks!
pwinters24 is offline
post #2 of 7 Old 12-08-2012, 04:47 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Yes.
Down the road you may realize that having all the volume controls at (on) the speaker selectors is in fact simple but not at all convenient.
cshepard is offline
post #3 of 7 Old 12-09-2012, 06:56 AM
Whip Rossovich's Avatar
Is there a need for any amp in that setup?
Whip Rossovich is offline
post #4 of 7 Old 12-09-2012, 09:41 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
That receiver has a Zone2 amp built-in ("powered zone 2").
jautor is offline
post #5 of 7 Old 12-09-2012, 11:08 AM - Thread Starter
pwinters24's Avatar
Originally Posted by cshepard View Post
Yes.
Thanks for confirming! Agreed on the convenience but my wife probably thinks I'm overdoing it with this type of setup and cost.
post #6 of 7 Old 12-11-2012, 10:54 AM
Is the powered zone 2 enough for multiple pairs of speakerS? If so, how many?
aloxton likes this.
post #7 of 7 Old 04-13-2013, 12:16 PM
aloxton's Avatar
I am planning a very similar setup to this, from what I have heard, as long as the speakers are 8ohms and to be used for background music it would work fine. I was told I may struggle a little if I tried to blast out music at a party! But I am most definitely a beginner at this.
aloxton is offline
Reply Home A/V Distribution
