Nuvo Concerto and HAI Omnipro II Install - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-08-2012, 07:29 PM - Thread Starter
lividami's Avatar
This is my first post to AVS and i thought i would share the install i did for my house. I spent a lot of time researching products for whole home audio and home automation and came up with a pretty good solution, although not perfect by any means in my opinion, but I’ll get into that later.
What made this process easier for me was i was able to start from scratch. I bought my house as a foreclosure and my plan from the beginning was to gut it out and start over. This allowed me to not limit my choices and really open my mind to what was out there. Sometimes the hardest part of installing something new in your home is finding out what is even compatible with your situation. Another added bonus was that i was doing all the work myself. From installing the equipment, to framing the walls, i was the general contractor for my house. It really helps to know every stud and nail location within your home.
From the very beginning, the biggest concern I had was future proofing my install. That is why I made the decision to not install a video distribution solution. The technology in my opinion just isn’t there for the consumer. However, I do believe the future of audio/video will be Ethernet which is why I ran over 5,000 feet of it in my 1400 sq. ft. house. The argument can definitely be made that eventually Cat6 will be replaced by something greater, but I’m banking that for audio/video, it will provide enough bandwidth to accomplish the task. I just hope industry moves in the way of IPTV or something even greater for the future.
The video solution I did implement was a central repository of media that is distributed to XBMC clients. I built a separate HTPC for each tv in the house and it works very well.
All in all, I ran over 9,000 feet of low voltage wire to include Ethernet, 14/4, 22/2, 16/2 and 18/4(I’m sure there were some others, but I can’t remember at this point). I took the time to research each kind of wire and made sure that I got the appropriate wire for the device. For example, all my smoke, CO, and gas detectors are fed with Red Riser-rated PVC: FPLR 18/4.
I decided on the HAI OmniPro II for my home automation controller. The basic reasons for choosing this controller was it has been around for years and has a good community following. This has allowed me to troubleshoot issues with relative ease. For the whole home audio, I went with the Nuvo Concerto. I wanted something that was hardwired in the house and is relatively easy to use. Nuvo for the most part fit that bill.
What really makes the system good is the central repository of media. I installed a Synology DS1812+ with 24 TB total and 16 TB usable after fault protection. The DS1812+ is gold standard for my media. The devices do not actually connect to this device, but rather all the data is replicated to a VMWare ESXI 5 server with ~10 TB of storage running 5 VM’s.
-Music Server (Windows 7 and Itunes)
-XBMC server (Ubuntu 12.04)
-Firewall/Router (pfsense 2)
-File Server (Windows Server 2008)
-Web Server (Ubuntu 12.04)
The music server feeds the Nuvo system by syncing my music library in itunes to the music port elite using the Nuvo client. I wanted a separate VM for this task because I have a very large music library and didn’t want other programs on the OS to mess with the process.
The XBMC server contains the MySQL database for the central media libraries.
The File Server is responsible for syncing data between the Synology DS1812+ and ESXI server. Also it has network shares setup so all the devices can access the data.
The Web Server hosts intranet webpages on how to use the system. It’s a rather complicated system so I developed tutorials on how to use it. Anyone who is connected to my network and goes to http://home/ will get a webpage with howto’s for the system. Believe me, if you don’t educate your family on how to properly use the system, the whole concept is pointless and a very expensive boat anchor.
It’s a fairly complex setup, so I don’t really want to go into the details of how it all works together, but hopefully this will give you some ideas of what is possible.
Now I want to talk about the negatives of this system. The major complaint I have is with Nuvo. I purchased the Concerto because it was their top of the line solution. Since I have installed the system, I have gone through 2 RMA for the Music Port Elite. I have a very large music library and the previous 2 units failed during the syncing process. I will say their support has been excellent. I had to do everything through my dealer, but luckily I have an awesome Nuvo dealer(who btw supported me installing the system myself which I know is rare due to Nuvo’s ridiculous policies). The other major complaint is no Android support. I don’t like apple and I’m stuck with using an iPad to control my system. For the Concerto being the top of the line product from Nuvo, it is unacceptable that they are unwilling to support Android. I have contacted them and I got response back that says they are currently not planning to support it either. I also think the keypads are useless, I don’t know if I have big fingers or what, but it never seems to respond to my touch. So they have become more of a fancy room clock more than anything. On the HAI side, I’m disappointed with the lack of style in their devices. For example, the Omnistat2 Thermostats looks horrible mounted on the wall, but they do the job very well and for the most part I’m happy with them. But that can be said for most of HAI’s interfaces, to me, it looks like they were built in the 80’s.
I don’t want to list every piece of equipment I installed, but if you look at the pictures, I think you’ll see 90% of it. All in all, I’m very happy with how it works. I use the iPad to control XMBC, Nuvo, and HAI (with 3 separate apps, XMBC Constellation, Nuvo App, and Haiku). The app switching is kind of annoying, but is manageable. I’m really hoping Nuvo gets some common sense and supports Android.
The next thing I’m going to work on is installing a RadioRa system. Hopefully it does what I want I want it to do.
lividami is offline
post #2 of 5 Old 12-09-2012, 08:50 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Wow, impressive setup. That's a ton of work.
I too am disappointed with the lack of Android support, for the MPS4.
I too had issues trying to set up the MPS4, RMA'd twice, but great support.
Would you use 2 racks next time? Those Nuvo wall plates, and the network switch, could go in a rack.
Happy with the Sanus rack? Sanus fans in that rack?
I've had zero issues with the Nuvo OLED keypads, love them.
You could pretty easily still hide those cable bundles with some lengths of split flex conduit - conduit that's split down the side, just slip it over the bundle. I'll be using it myself, for that purpose.
You must be very proud of all of that! Thanks for sharing.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 5 Old 12-09-2012, 09:58 AM - Thread Starter
lividami's Avatar
Why did your Music Port Server's fail? Did it happen during the syncing process?
I wanted to separate the main house network switch from everything else, that's why i mounted it to the wall. I did include a Netgear Gigabit swtich in the rack for all the rack devices.
I'm actually very happy with the Sanus rack and Sanus Ecosystem. The one issue i had was trying to get a good server case that fits the shallow rack and that will also hold 10 hard drives. But after some serious searching, i found the case: iStarUSA D407P-DE6BL Blue Steel 4U Rackmount.
If anything, what i might do next time is separate the AV equipment from the computer equipment via two different racks and most likely 2 different locations. I have 2 different UPS solutions, a PANAMAX MB1500 with a Furman BATT1500-EXT External Battery Pack for the AV equipment and 1 CyberPower Smart App Sinewave with 3 CyberPower BP48V75ART2U Extended Battery Packs for the computer equipment. All those batteries took up a lot of space in the rack, but it was essential because of where i live and the power reliability. It's pretty cool to have the power go out and be able to listen to your Nuvo system in complete darkness.......
I was thinking about that, but for now, it hides nicely behind the rack. My only concern would be the power lines and the audio/low voltage cables. I wouldn't want any interference to mess with the signals. Do you think t here would be any chance of that?
lividami is offline
post #4 of 5 Old 12-09-2012, 06:42 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
One time, the MPS4 bricked when I tried to set a static IP.
The other time, I was adding my keypads one at a time, and it stopped working correctly. I started over, with a single KP at the rack, and it still wouldn't work.
Since I bought everything from an Authorized Nuvo distributor, RMA was a breeze.
Maybe I could start an email campaign. Everyone who wants MPS4 control with Android, contact Nuvo. I'd gladly pay $100 for that app.
You only need to worry about AC cables. The Nuvo cables, after the brick transformer, is DC, and not a concern. Keep all the AC cables on one side of the rack, and all other cables on the other side. Use lacing/lacer bars to bring them to one side or the other. Some components may need a couple lacing bars behind them, one for AC and the other for LV/DC.
Neurorad is offline
post #5 of 5 Old 12-09-2012, 06:44 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Yeah, I bought a UPS for my equipment, and we listened to the Nuvo in the dark, for an hour, last power outage. Not too useful, still looking for a better use for it. wink.gif
Neurorad is offline
Reply Home A/V Distribution
