Telephone Line connected to Electrical Outlet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-09-2012, 01:27 PM - Thread Starter
dlauney's Avatar
I'm attempting to create another structured wiring termination upstairs basically to install a Ethernet switch. My plan is to repurpose a cat5 phone line to an upstairs bedroom that terminates at the structured wiring box downstairs. I currently have a switch in my box downstairs, so I'll use this phone line to connect the downstairs switch to the upstairs switch enabling me to add additional ethernet ports throughout the house accessible from upstairs attic.
However, when I located the cat5 wire to the phone in the bedroom, I noticed that it goes into an electrical box and then connects to another cat5 wire that seemingly goes to the structured wiring box downstairs. My question, what is this box that the cat5 is going into?
dlauney is offline
post #2 of 8 Old 12-09-2012, 01:34 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
A small DC transformer that provides lighted phone dials on old Trimline phones and others. It's hard wired to power, so be careful and turn off power if you want to remove it.
jautor is offline
post #3 of 8 Old 12-10-2012, 07:15 AM
SAM64's Avatar
Liked: 78
Sorry to nitpick, but transformers only operate on and output AC.
SAM64 is offline
post #4 of 8 Old 12-10-2012, 07:47 AM
jautor's Avatar
Liked: 778
Sorry, I was being simple. A DC power supply. A hard-wired "wall wart" without the plastic case. biggrin.gif
jautor is offline
post #5 of 8 Old 12-10-2012, 08:39 AM
SAM64's Avatar
Liked: 78
That's just a transformer, the output is AC.
SAM64 is offline
post #6 of 8 Old 12-10-2012, 08:51 AM
jautor's Avatar
Liked: 778
Thanks for the correction. I wondered about that - just always assumed it was ~24VDC (since we're talking about Bell stuff). But I guess since it was just a small lamp load, which would work fine with AC, there was no reason to add the rectifier cost, etc. And yes, those certainly look like transformers... I never measured one!
Ok, I learned something this week - and it's only Monday.
Jeff
jautor is offline
post #7 of 8 Old 12-10-2012, 09:20 AM
SAM64's Avatar
Liked: 78
POTS equipment operates at -48VDC. Ring signal is ~90VAC.
SAM64 is offline
post #8 of 8 Old 12-10-2012, 10:55 AM
jautor's Avatar
Liked: 778
(I meant DC vs. AC usage... cool.gif But yes, you're absolutely correct.)
I was also surprised, looking it up, how low the AC voltage output is on those (6-8V). It really is a small load, after all.
jautor is offline
Reply Home A/V Distribution
