HDMI splitter 1 into 2 or 1 HDMI into 1 HDMI and 1 component - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-10-2012, 04:13 AM - Thread Starter
Cyclone82's Avatar
I am looking for a device that that can split 1 HDMI into either 2 HDMI or 1 HDMI and 1 component out
i am considering this upscaler
http://www.solarisjapan.com/products/XRGB%252dmini-Framemeister-Compact-Up-Scaler-Unit.html
I would like to feed one HDMI out direct to TV and then another one i want to downscale to component (probably with HDFury) so i can record from that to a hauppauge hd pvr or similar. I want both outputs to be on simultaneously but if i could turn either one off that could be useful.
As those are expensive good quality items i dont want to have a $10 splitter as the weak link in the chain and prefer something of equal quality to the other gear.
Do i need a powered splitter? can you get un-powered ones? If so is there a reduction in quality? Do i need amplification if i split 1 HDMI into 2
Are things like this good
http://www.ebay.com/itm/ViewHD-HDMI-Bi-direction-2x1-1x2-A-B-AB-A-B-Switch-Switcher-Support-3D-/280781012558?pt=US_Video_Cables_Adapters&hash=item415fda3e4e
http://www.ebay.com/itm/ViewHD-1x2-HDMI-Splitter-v1-3b-One-Input-Two-Output-/270641169821?pt=US_Video_Cables_Adapters&hash=item3f0378859d
or would i want something better from a more known brand?
Thanks for your advice
Cyclone82 is offline
post #2 of 5 Old 12-10-2012, 05:22 AM
ccotenj's Avatar
Liked: 101
i have used these (still do, ftm) without issue for splitting... personally, i have had far more luck with powered iver passive units...
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10113&cs_id=1011306&p_id=8204&seq=1&format=2
it's unlikely that you will find one that "splits" to hdmi and component... you would need to use a grey market device (such as the one you noted) on the other side of the splitter for that.
- chris
ccotenj is offline
post #3 of 5 Old 12-10-2012, 02:47 PM - Thread Starter
Cyclone82's Avatar
I was also considering something like this too.
http://www.kanexpro.com/item/?id=HD2PSPB
Anyone used that?
The Monoprice has good reviews it seems
post #4 of 5 Old 12-22-2012, 10:00 PM
BB99's Avatar
Are you using that monoprice unit with a 5V power supply (not included)?
This one: http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10113&cs_id=1011306&p_id=8154&seq=1&format=2
slightly more expensive, includes the power 5V supply. I wonder if something like a Hum-X is needed if I'd be driving 2 TVs in 2 different rooms, which are powered by 2 different AC circuits?
BB99 is offline
post #5 of 5 Old 12-23-2012, 06:58 AM
BB99's Avatar
Cyclone82: if you don't have luck finding a single unit, you could first run to an HDMI 1:2 splitter then run one of those outputs to this HDMI to component converter:
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011410&p_id=8125&seq=1&format=2
(I haven't used it so I'm just pointing it out, but it seems to get good reviews)
BB99 is offline
Reply Home A/V Distribution
