Looking for Single-Gang keypad to control Denon/Sony receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-11-2012, 04:45 AM - Thread Starter
atomarchio's Avatar
I am looking to replace B&K CK1.1 Keypad installed in my kitchen several years ago.
It was controlling Zone 2 on my Sony STR-DA3500ES receiver. I am switching receivers an am now unable to program this keypad.
Is anyone aware of single-gang installed keypads for controlling a Denon or Sony receiver.
I only need this keypad to control Zone 2 and turn up/down volume. My preference would be to mount this in the wall similar to where I had the previous keypad mounted. I don't want a universal remote or something portable.
I am having a tough time finding options.
Please let me know. Thanks.
atomarchio is offline
post #2 of 14 Old 12-11-2012, 07:30 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Do you need to select the zone 2 source with this KP, or just volume up/down? Unclear from your post.
If only volume control, you could use an in-wall VC.
If you want to select the source, from the keypad, it will involve a lot more effort to set up, with programming. I suggest hiring someone to do it, using Xantech, RTI, or URC - installer's choice.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 14 Old 12-11-2012, 08:04 AM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
Why can't you program the keypad? Is it not functional, or do you not have the software?
jautor is offline
post #4 of 14 Old 12-14-2012, 04:36 AM - Thread Starter
atomarchio's Avatar
I have the software and cable. However, the device needs an external power supply to be configured and the installer did not leave one.
How would I power up the keypad connected when connected to my computer? If I can figure out this part I can probably do it myself.
post #5 of 14 Old 12-14-2012, 09:49 AM
SAM64's Avatar
Liked: 78
Use a 12VDC power supply, available almost everywhere.
SAM64 is offline
post #6 of 14 Old 12-14-2012, 09:57 AM
jautor's Avatar
Liked: 832
+1. Or take your computer to the keypad, or connect the keypad to the amp with a temporary cat5 cable...
jautor is offline
post #7 of 14 Old 12-14-2012, 05:53 PM - Thread Starter
atomarchio's Avatar
Would this actually work? This would be much easier than cutting wires.
post #8 of 14 Old 12-14-2012, 07:07 PM
jautor's Avatar
Liked: 832
Why wouldn't it?
jautor is offline
post #9 of 14 Old 12-16-2012, 05:29 AM - Thread Starter
atomarchio's Avatar
Why wouldn't it?
I just tried an Ethernet cable from keypad. Plugging in an Ethernet patch cable still does not power on the device. It's the same scenario as with the other cable I have.
I also noticed the software is looking for a connection the COM ports. I don't think it would find the device via Ethernet.
So how I do power on this keypad?
post #10 of 14 Old 12-16-2012, 07:32 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Have you googled B&K Programming Manual, and B&K Installation Manual?
I didn't read them, but the KP is most probably powered by the B&K controller.
If you don't have an RS232 port on a PC, you'll need a USB adapter, as mentioned in the Programming Manual. Pro can re-program, if you're not up to it. Hand him the manual, when he arrives, if he doesn't have B&K experience.
Neurorad is offline
post #11 of 14 Old 12-16-2012, 07:48 AM
SAM64's Avatar
Liked: 78
This device doesn't have any ethernet ports on it, so, don't do that.
If you google the part number, you'll get the operators manual, it shows the pinouts for the power supply, rs232 interface, etc.
SAM64 is offline
post #12 of 14 Old 12-16-2012, 05:26 PM - Thread Starter
atomarchio's Avatar
It says I should purchase a 12V power supply but I don't which one to buy. I've never done this before so any help you can provide on how to connect the power supply to the interface of the keypad? What tools would I need to purchase?
post #13 of 14 Old 12-16-2012, 07:24 PM
sv650s's Avatar
http://*******/WhODjP
Page 3 of the manual shows the pin-out fir the connector. If you use a xantech 789-44 you can cut the cable and run the wires into the connecting block and have 4 ir outputs to control the receiver as well as other components. Use the 781-RG power supply and you will have no problems with powering the keypad.
http://www.xantech.com/files/manuals/96_78944.pdf
sv650s is offline
post #14 of 14 Old 12-17-2012, 04:36 AM - Thread Starter
atomarchio's Avatar
I am currently using the 781-RG with the connecting block now. The wires on it are not cut so I can't cut them in order to use with powering the keypad for programming. How should I handle this?
Reply Home A/V Distribution
