Interesting Way To Set up Multi-zone - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-13-2012, 06:16 PM - Thread Starter
Rasta Linus's Avatar
I was looking around the web for multi-zone solutions and I came across this one. It's connecting DMX controlled amps together and is controlled by an iOS device. The company that suggests this layout is out of Spain and I could not find any U.S. type setups or devices that make it possible. I'm sure I didn't look hard enough or don't know what to search. I'm a newb and wanted some opinions on this setup. I would appreciate any. Thank you!!
http://www.makeitworkblog.com/build-a-multizone-audio-system-controlled-by-ipad/
Rasta Linus is offline
post #2 of 4 Old 12-14-2012, 01:46 AM
Joe Fernand's Avatar
Quoted: 293 Post(s)
Liked: 171
Probably best if you can outline what you are trying to achieve and then folk can fire in some suggestions – there are lots of iOS Apps + Networked Control hardware options you could use with all manner of kit via RS232 and or IR.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #3 of 4 Old 12-15-2012, 03:38 PM
Gramin's Avatar
Why not go the uber-easy route and grab some Sonos units? For each Sonos Amp, you create a new zone. Each zone can play its own music at its own level; or you can group zones together, and all zones can play the same thing (though still able to control volume for each zone independently).
Rasta Linus likes this.
Gramin is offline
post #4 of 4 Old 12-18-2012, 12:12 PM
ljo000's Avatar
I created a cheap DIY multi-zone audio system using Logitech Squeezebox server software on my HTPC and regular 2ch amps. Controllable via iOS or Android dedicated apps (free), WebOS app (paid) or just a web browser.
Code:
http://www.avsforum.com/t/1350118/running-multiple-softsqueeze-streams-from-one-pc
The best part is that if you have any amp, speakers and PC, you can test it out for free very quickly and easily.
ljo000 is offline
Reply Home A/V Distribution
