Adding Wired Network Connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-14-2012, 06:19 AM - Thread Starter
digitish's Avatar
Did some searching but could not find an answer. I upgraded to a network receiver & would like to add a wired network connection but dont want to run cat6 cable all the way across the house. I can make wireless work or i could try the power outlet adapters but i've read that the connections can be spotty. I do have a comcast cable box in the room where the receiver is so the questions is can i split the incoming cable connection, buy another cable modem & split the signal...one to run cable & one to run internet? Would be nice to have a wired connection to the xbox as well if this can be done. thanks!
digitish is offline
post #2 of 9 Old 12-14-2012, 06:44 AM
gregzoll's Avatar
Liked: 33
Wireless Bridge, Ethernet over Power. If this house is on a basement or crawlspace, you can pull the cat-5e that way, or through the attic and then down inside the wall. It is only worth pulling Cat-5e/6 if you are pulling a bunch of runs, not just one. Also not worth it getting a second modem on another account just for one device.
I would go with either http://www.netgear.com/home/products/powerline-and-coax/ or any of these http://www.netgear.com/home/products/wireless-range-extenders/
To figure out any interference or your wifi range, use something like inSSIDer to figure that part out. How large of a place are we talking in distance from where the catv modem is, to where the AVRS will be?
gregzoll is offline
post #3 of 9 Old 12-14-2012, 07:06 AM - Thread Starter
digitish's Avatar
Thanks for the suggestions.
House is not that big, typical raised ranch. Cable modem is downstairs & AVR is upstairs.
Another cable modem is only about $60 if i can simply split it off the cable box line.
Seems like the other option is just by AppleTV, but with that i am still stuck with wireless.
digitish is offline
post #4 of 9 Old 12-14-2012, 09:01 AM
gregzoll's Avatar
Liked: 33
If you can pull ethernet, do it for all rooms, not just one run. As for wifi, it depends on how many A/P's are around you, which will cause the most interference.
gregzoll is offline
post #5 of 9 Old 12-14-2012, 09:06 AM - Thread Starter
digitish's Avatar
Sorry, but what are A/P's?
digitish is offline
post #6 of 9 Old 12-14-2012, 10:02 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 258
So do you not have attic access? I am not positive that you could have two modems on your account.
NickTheGreat is offline
post #7 of 9 Old 12-14-2012, 11:17 AM
gregzoll's Avatar
Liked: 33
Access Points.
gregzoll is offline
post #8 of 9 Old 12-14-2012, 11:18 AM
gregzoll's Avatar
Liked: 33
Only if one is being used for a emta for voice, and the other for voice, would be the only way they are going to get two modems in the same household.
gregzoll is offline
post #9 of 9 Old 12-14-2012, 11:47 AM - Thread Starter
digitish's Avatar
Thanks guys. I will try to get a cable up to the attic then back down.
digitish is offline
Reply Home A/V Distribution
