Advice for Subwoofer Balun at back of room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-14-2012, 12:26 PM - Thread Starter
FuRoSh's Avatar
Hi I wanted to get some recommendations for doing the following:
Run my single-RCA (subwoofer) out of Denon Receiver --(to)--> L/R Audio klipsch Subwoofer.
I currently have a single subwoofer cable going to a Y-Adapter to my subwoofer.
I also have (2) Cat5E cable runs from plate near receiver to back of room.
Now I want to connect Sub to back of room, so I bought a pair of Niles C5-HDDA Baluns. The Niles C5-HDDA is a CAT-5 Component Video and Digital Audio Balun.
C5-HDDA image
I setup like this:
[Receiver] <-- (single Subwoofer Cable) --> [C5-HDDA Digital Audio connector] - [RJ45]<--(Cat5E)--> [RJ45] - [C5-HDDA Digital Audio connector] --(Single Subwoofer Cable)-->(Y-Adapter Cable)---> [L/R Audio Connector on Subwoofer]
I believe the Niles I bought on eBay did not work. Seller stated New, but one was scratched and I did multiple tests to rule out Niles Baluns but everything I tested pointed to them not working.
- I made sure cable wiring was using T568A standard as Niles manual states.
- I used a Cat5 ethernet cable tester and verified good cables.
- I ran brand new cable (tested) directly on floor to test again and still didn't work.
- I tested (store-bought) 6" patch-cable (cat5e) to eliminate distance and still didn't work.
- Then to verify my equipment was all working I bypassed the Niles Baluns and ran cables directly to subwoofer and subwoofer worked fine.
*I also have a networking (IT) background and have ran ethernet cable in past.
Questions:
[Receiver] - (sub cable) - [Audio Balun] - (cat5e) - [Audio Balun] - (sub cable) -- (Y-Adapter) - [Subwoofer]
This should work fine correct?
Is there a preferred Balun to use here?
A. Digital Audio Balun
B. Standard Audio (L/R) Balun with (2) Y-Adapters ?
or
C. Coax Balun
D. Component Balun and use any one of the single cables to pass audio through? (not to sure this would work but guessing in theory it sould)
*Also I really do not want to replace my 2 Cat5E in-wall jacks for a Wall Plate Balun so prefer to use a small balun at each end.
FuRoSh is offline
post #2 of 10 Old 12-14-2012, 01:37 PM
SAM64's Avatar
Liked: 78
You're trying to send a low bandwidth, low frequency analog signal through the port designated for SPDIF?
Chances are there's a high pass filter on this.
Try connecting everything directly, eliminating the BALUNS
SAM64 is offline
post #3 of 10 Old 12-14-2012, 01:52 PM - Thread Starter
FuRoSh's Avatar
First thanks for you response.
SPDIF port?
The receiver has SW out, Balun has Digital Audio IN/OUT, subwoofer has L/R IN. Sorry don't know which port exactly you're referring to. Is SPDIF same as any I just listed?
Denon AVR-3808CI A/V Receiver rear image:
http://www.audioenz.co.nz/2008/images/denon_3808-rear-l.jpg
> Connecting directly?
Are you suggesting connecting the Cat5 cable to sub using RCA connector?
I opted to go with Cat5E (multiple-purpose) cable w/ Baluns rather than running long Coax (single-purpose) cable to back of room or higher-end $costly$ Subwoofer cable that I needed about 150FT (Up wall, across ceiling, down wall) to back of room.
FuRoSh is offline
post #4 of 10 Old 12-14-2012, 02:24 PM - Thread Starter
FuRoSh's Avatar
Sorry if this was misleading, I actually moved my subwoofer back by my receiver to verify all my equipment was still working to bypass baluns.
FuRoSh is offline
post #5 of 10 Old 12-14-2012, 03:06 PM
jautor's Avatar
Quoted: 1327 Post(s)
Liked: 850
You should use an analog audio cat5e balun pair instead. I use the MuxLab 500028 balun to connect a sub over cat5. Works fine.
http://www.muxlab.com/products/ve_avd_stereo_hifi_balun.html
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #6 of 10 Old 12-16-2012, 10:38 PM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
As Jautor said, use a standard audio balun, not a video or digital balun. The nice thing about the straight audio baluns, is that they don't have a power adapter, actually, no power at all. Easy-peezy.
I use SnapAV units.
ifor is online now
post #7 of 10 Old 12-17-2012, 04:51 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
cshepard is offline
post #8 of 10 Old 12-17-2012, 09:48 PM
jautor's Avatar
Liked: 850
Originally Posted by cshepard View Post
This one's so much sleeker!
http://www.muxlab.com/products/ve_avd_stereo_audio_balun.html
Agreed that it's sleeker, but the specs aren't as good as the "HiFi" balun, and this one talks about "good midrange performance" which is why I spent the extra $20 for the other one...
post #9 of 10 Old 12-20-2012, 12:16 AM - Thread Starter
FuRoSh's Avatar
Thanks guys! I submitted my info to MuxLab to find reseller but can you recommend a good source to purchase from?
Google shopping shows several online stores like 123securityproducts.com
FuRoSh is offline
post #10 of 10 Old 12-21-2012, 02:04 AM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Got Amazon? http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=MuxLab+
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Home A/V Distribution
