How does pre-wired ethernet work? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #91 of 243 Old 04-08-2015, 12:48 PM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
You got it!
Nice work, Jeff. Is this all billable?
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
post #92 of 243 Old 04-08-2015, 12:52 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
If those invoices stopped bouncing, sure...
jautor is offline
post #93 of 243 Old 04-09-2015, 06:10 AM
Liked: 0
Hi Jeff,
Thanks for taking a look and for responding so quickly!
I am based in Frankfurt, Germany but only recently moved here. Unfortunately I do not own the place otherwise I would look into replacing the block with a patch panel.
To connect to an ethernet switch, would I just run each of the same wires from the "wiring block" into their own RJ45 jacks?
applesandpears is offline
post #94 of 243 Old 04-09-2015, 06:38 AM
jautor's Avatar
Liked: 777
Yes, punch down color-for-color and terminate the other end with an RJ45. Attach those to an Ethernet switch located there.
And note you have to remove the red/black jumper wires from the punch block on any room you're connecting as Ethernet.
jautor is offline
post #95 of 243 Old 04-28-2015, 04:01 PM
Liked: 0
Hi All,
I just moved into a 3 level townhome and am in pretty much in same situation. Below are the details of my setup.
Level 1 Garage and small office room.
Level 2 kitchen and living room
Level 3 Bedroom and bedroom 2
Service provider: Comcast
Current setup in living room at Level 2: Cable modem to Apple time capsule wireless router. from wireless router to network switch. from network switch to all the media devices (Apple TV, PS3, Smart TV, TIVO). from the wall from where Comcast cable is coming out there are 2 Ethernet ports. I have tried to go from the wireless router to either of the connectors on the wall to see if i get any internet through wall in other rooms but its not working.
I went to garage where i found the wiring box. which had bunch of ethernet cables as well as other cables. By looking at the pictures can anyone suggest what i would need to do to get internet in all the rooms via RJ45 jacks in each room?
Pictures are not that great but will try to get better pictures if its required.
ID:	691754   Click image for larger version
ID:	691762   Click image for larger version
ID:	691770   Click image for larger version
tamuk is offline
post #96 of 243 Old 04-28-2015, 04:56 PM
jautor's Avatar
Liked: 777
The good news is you have most, perhaps all, of the pieces you need. But you may need a tool to finish the job.
The jacks in your house appear to be wired for telephone usage. But they did you a big favor by adding the network module (punch down block / patch panel) below the phone module. You'll need to move the wires for the jack(s) in the other rooms you want to use for Ethernet from the phone module to the network module.
Then you'll place an Ethernet switch here, and use patch cables to connect the switch to the network module. And one of those must be a line going to your living room, which will be connected to your wireless router (or Ethernet switch).
To do that work, you'll need a punch down tool, like this one:
http://www.amazon.com/Tripp-Lite-N04...unch+down+tool
Jeff
jautor is offline
post #97 of 243 Old 04-28-2015, 06:26 PM
Liked: 0
Jeff
Thanks Jeff. I am new to this so please bear with me.
Did you mean
1. I need to change the jacks on the walls of every room? if so why? those seem to fit the RJ45/ethernet cables.
2. do i need to buy another ethernet switch and place it in the wiring area? If so can you recommend one?
3. i need to move all the yellow cables to the network module below it?
If possible can you draw something for me based on the pictures?
Appreciate all the help.
thanks
aj
tamuk is offline
post #98 of 243 Old 04-28-2015, 06:51 PM
jautor's Avatar
Liked: 777
Did you mean
Wrong end. We're talking about the end in the box here. If the room jacks are RJ45 (and they wired all 8 conductors), you don't have to change anything in the rooms.
Yes, and any cheap $10 switch will do. For $20 you can get a gigabit Ethernet model.
"All" the ones you want to convert to Ethernet, and don't need for wired phone connection.
(oh, and see post #28: How does pre-wired ethernet work? )
jkxmlr and tamuk like this.
jautor is offline
post #99 of 243 Old 05-01-2015, 04:13 PM
Liked: 0
Thanks for the inputs.
Below are new things which I found out by taking the jack plates out of the wall. Each plate has Cat5e connector and opening for another jack to mount. Behind each plate i did see blue ethernet cable besides yellow ethernet cable which is connected to the existing jack.
The issue is if i only want to connect one room the cables are not labelled. Is there an easy way to figure out which cable is going to which room?
Please take a look at the drawn picture for the network block setup and let me know why the one of the coax cable is on the network block and other one is split and attached to AFL telecommunications Splitter filter. Also attaching the pictures so hopefully you will get an idea.
By looking at the network block setup please let me know i need to remove/discoonect any cables from any of the components shown in the picture.
My plan is to add CAT 6 jacks to all the plates in addition to the existing CAT5e jacks and connect all the Blue ethernet cables from behind the plates to the jacks.
I am not sure about the network block connections so would appreciate your help on that.
ID:	696050   Click image for larger version
ID:	696058   Click image for larger version
ID:	696066   Click image for larger version
ID:	696074   Click image for larger version
tamuk is offline
post #100 of 243 Old 05-02-2015, 12:05 AM
jautor's Avatar
Liked: 777
Oh, that's good news! Couldn't make it out clearly in your first set of pictures, but this is even easier now. You've got several blue cables there not even hooked up. So no need to move the yellow wires - just punch down the blue ones onto the network block, and add RJ45 keystones for the room jacks.
With a volt/ohmmeter, yes, you can strip and tie a pair together at the room end and check for continuity back at the box. I'd just go ahead and punch all of them down and put jacks in the 3-4 places you've got wires. Then you can easily test your work with a cheap network tester (or just connect a device and see which ports light up!).
That's a DSL splitter, wired to split the phone from the DSL modem. The black coax isn't connected, it's just being used to support the wires, I assume...
Unless those blue cables are cat6 (highly, highly unlikely), you should use cat5e keystone jacks for these connections. Cat6 keystones would be a waste of money and will just make things more difficult.
Punch down the blue cables on the network block. Then you'll use RJ45 patch cables to an Ethernet switch. Back to the diagram on page one of this thread...
Jeff
jautor is offline
post #101 of 243 Old 05-10-2015, 11:56 PM
Liked: 0
Jeff
Thanks. Jeff. Everything worked out ok. Thanks for all the inputs!
tamuk is offline
post #102 of 243 Old 11-29-2015, 05:11 PM
g0ldm4g3's Avatar
Liked: 0
Hey Jeff!
You seem pretty knowledgeable with pre-wired Ethernet ports lol
Sorry if this is considered bumping an old thread, I can't PM you, plus I felt my issue was still on topic.
My 2 story home has Ethernet/coaxial ports all over the place. A couple with blue (cat5e)/yellow (phone line, I think)/coaxial combos.
When I was studying at Texas Tech, the dorms came with Ethernet jacks that you could just plug your laptop in.. and wala.
That doesn't seem to be the case in my house.
As a matter of fact, there's only one port that provides internet service and that is my game room.. as it is connected to a modem > router.
Unfortunately, we have a Smart TV downstairs and in my room and the signal isn't strong and would rather it plug directly to the Ethernet port behind it.
Could you explain to me what I should do?
I can provide pics, if needed.
*I know where the central hub is, upstairs guest room, I can provide pics.
*The modem and router used to be in the downstairs exercise room, but a Comcast rep moved it upstairs to the game room.
*I'm not sure if I need a modem to plug into the Ethernet port for the internet access, unlike my stay in the dorms?
g0ldm4g3 is offline
post #103 of 243 Old 11-29-2015, 06:21 PM
FlyingDiver's Avatar
Quoted: 203 Post(s)
Liked: 58
You've got a modem and router, you probably just need an ethernet switch installed in that central hub location. Open it up and post a picture of the insides. Post one with the entire cabinet, then a few more with closeups of the devices that are in it now.
FlyingDiver is offline
post #104 of 243 Old 11-29-2015, 06:38 PM
g0ldm4g3's Avatar
Liked: 0
Sounds good!
I'm at the movies with my gf now, but I did take a couple pics before heading out
Ahh, apparently I need 5 posts before I can post a pic
Panasonic 65" Plasma Viera/Bose Lifestyle Series II/Roku 3
Toshiba 49" LED (49L310U)/Vizio 5.1 Soundbar (s4251w)/Amazon FireTV
g0ldm4g3 is offline
post #105 of 243 Old 11-29-2015, 06:39 PM
g0ldm4g3's Avatar
Liked: 0
I'll upload to imgur when I'm free
g0ldm4g3 is offline
post #106 of 243 Old 11-29-2015, 11:52 PM
g0ldm4g3's Avatar
Liked: 0
Here are the pics I have.
Upon further investigation.. It seems that the blue is for phone line and yellow may be for Ethernet? Lol.. I used to have a cordless phone hooked in that empty blue port... And the line connected in the other pic is from our Vonage adapter.
With that said, that's the main box, pic with the blue/yellow/coaxial port is where the modem and router are, and the pic with the blue cat5e/coaxial combo port is where I would like Ethernet access for my TV or streaming box
g0ldm4g3 is offline
post #107 of 243 Old 11-30-2015, 05:05 AM
Quoted: 203 Post(s)
Liked: 58
No pics
post #108 of 243 Old 11-30-2015, 01:50 PM
g0ldm4g3's Avatar
Liked: 0
No pics
Ahh, sorry!
Here:
imgur(dot)com/a/I24Cp
g0ldm4g3 is offline
post #109 of 243 Old 11-30-2015, 01:52 PM
g0ldm4g3's Avatar
Liked: 0
5 posts done!
Here are the pics
g0ldm4g3 is offline
post #110 of 243 Old 11-30-2015, 01:53 PM
g0ldm4g3's Avatar
Liked: 0
The yellow lines have no ends on them and the blue lines have writing on them corresponding to the rooms they're routed to
g0ldm4g3 is offline
post #111 of 243 Old 11-30-2015, 02:02 PM
jautor's Avatar
Liked: 777
We'll assume the yellow wires are the ones terminated with RJ45's for Ethernet... You'll need to terminate those loose ends and then install an Ethernet switch in the enclosure.
I can't make out the manufacturer (OnQ?) of the box and the other modules, but with that triple-module bracket you can probably get an Ethernet network module (a patch panel in the same form factor as the phone and coax modules you already have). That won't be the cheapest solution, but it will be a nice clean one. Then you'd just need some short RJ45 jumper cables to attach to an Ethernet switch.
This assumes you have your modem/router elsewhere and that unit can be connected via Ethernet cable to the enclosure.
Jeff
jautor is offline
post #112 of 243 Old 11-30-2015, 02:19 PM
g0ldm4g3's Avatar
Liked: 0
Jeff
I'm about to leave work now, I'll take a pic of the manufacturer when I get home.
I do know the name had 'fox' in it and the emblem had a yellow fox head
Sent from my SGH-M919
g0ldm4g3 is offline
post #113 of 243 Old 11-30-2015, 02:42 PM
jautor's Avatar
Liked: 777
Ok, that's a Greyfox enclosure with an OnQ/Legrand bracket. I see now there's an OnQ 7577 Telecom module there. I believe you'll want the Legrand / OnQ AC1000 module that will fit into that open bracket. It's ~$40 for really a simple 6-port keystone block, but it would fit correctly.
The cheaper solution is to just terminate the few yellow wires individually and connect them to an Ethernet switch directly. The issue with doing that is that you'll need tools and you don't want to damage those wires (such that you have to keep cutting off length to re-terminate).
jautor is offline
post #114 of 243 Old 11-30-2015, 03:10 PM
g0ldm4g3's Avatar
Liked: 0
Alright, seeing that my blue cat5e port was used for my cordless phone at the time.. It's not possible to acquire ethernet access in my room that has only the blue/coaxial combo?
g0ldm4g3 is offline
post #115 of 243 Old 11-30-2015, 03:46 PM
jautor's Avatar
Liked: 777
Assuming the blue wires are also cat5e, which is very likely, you can. If you don't need the phone connection in that room, you can move the blue cable off the telecom block and make it an Ethernet link instead. You'll have to re-terminate the keystone with an RJ45 (if it's not already one).
jautor is offline
post #116 of 243 Old 11-30-2015, 04:23 PM
g0ldm4g3's Avatar
Liked: 0
Correct. I won't need phone connection in this room.
So here's what I've got so far.
I will need to order:
to occupy the vacant bracket next to my OnQ Telcomm module and r7553 punchdown module.
Once that is installed, I will need to find the blue cat5e located on the punchdown module and terminate it as an RJ45,
the plug that in to my new 6 port keystone block.
Looking at this, how will this keystone block have internet access, what else would have to be connected to it while the other two modules sit in their brackets?
g0ldm4g3 is offline
post #117 of 243 Old 11-30-2015, 05:00 PM
jautor's Avatar
Liked: 777
Short RJ45 patch cables from the module to an Ethernet switch.
jautor is offline
post #118 of 243 Old 12-01-2015, 06:19 AM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
Jautor, he may also have to pay attention to the A and B wiring on the Keystone.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #119 of 243 Old 12-01-2015, 12:34 PM
jautor's Avatar
Liked: 777
True, he should look at that - although if he just cross-connects two rooms, assuming the jacks are all wired the same, it would take care of itself!
jautor is offline
post #120 of 243 Old 12-22-2015, 04:36 PM
Liked: 0
I am having a similar but different issue. I'm also trying to turn all my ethernet wall jacks "on", but when I looked inside my structured wiring panel, I found 2 cables that arent connected to anything. Only one is connected and running to my modem which is also connected my a coax cable in my living room.
my question is- how do I connect all my dsl wall jacks using what I have in my wiring panel?
this is whats in my panel.
ID:	1136842   Click image for larger version
ID:	1136850   Click image for larger version
skyeRO is offline
Reply Home A/V Distribution
