Building home extension - need recommendations on WHA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-27-2012, 12:34 PM - Thread Starter
newtek2020's Avatar
Experts,
We r adding a sunroom with three level extension. Would like to add audio in these three levels. I have a spare Onkyo 608, and would be interested in using it if possible.
Otherwise, our budget is tight so any recommendations on the multi-zone audio distribution solution would be appreciated.
In the basement, we will have a game room, level 1 would be sunroom, and level-2 is bedroom extension. Planning to add 2 in-ceiling speakers at 2 levels.
Any advice on wiring that need to be done for later date addition of the system is also appreciated.
newtek2020 is offline
post #2 of 2 Old 12-27-2012, 03:51 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 781
Same advice as always. Home run speaker wire to a central location where the gear can live. Loop speaker wire through a volume control / keypad location in each zone. Home-run a cat5e/cat6 to each keyapd as well. That will set you up to use any system available.
Jeff
jautor is online now
Reply Home A/V Distribution
