russound bgk1 i Bridge RNET question. can this be connected through a 10/100 switch? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-28-2012, 03:39 PM - Thread Starter
psreynol's Avatar
or does it require a dedicated cat 5 line? if yes, would using a POE compatible switch make any difference?
thanks
psreynol is offline
post #2 of 4 Old 12-28-2012, 07:19 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
Dedicated cat5 line point to point. It is NOT Ethernet.
jautor is offline
post #3 of 4 Old 12-28-2012, 07:24 PM - Thread Starter
psreynol's Avatar
ok, that is what I suspected. does it require a special punch down? thanks for the reply
psreynol is offline
post #4 of 4 Old 12-28-2012, 07:48 PM
jautor's Avatar
Liked: 780
Nope - straight through wiring following the same pattern...
jautor is offline
Reply Home A/V Distribution
